Selling my starlet as got a new project. She is a runner just needs an MOT. see below for mot fails
Do not drive until repaired (dangerous defects):
Nearside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
Offside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
Repair immediately (major defects):
Offside Indicator switch inoperative Switch faulty effecting operation of off side indicators (4.4.2 (a) (ii))
Nearside Rear Stop lamp(s) not working (4.3.1 (a) (ii))
Nearside Rear Registration plate lamp inoperative in the case of a single lamp or all lamps (4.7.1 (b) (ii))
Offside Front Position lamp not working Side light (4.2.1 (a) (ii))
Offside Front Headlamp aim projected beam image is obviously incorrect (4.1.2 (c))
Nearside Front Headlamp aim too low (4.1.2 (a))
Nearside Front Suspension arm ball joint dust cover no longer prevents the ingress of dirt (5.3.4 (b) (ii))
Offside Front Wheel bearing has excessive play (5.1.3 (a) (i))
Repair as soon as possible (minor defects):
Nearside Front Drive shaft joint constant velocity boot severely deteriorated (6.1.7 (g) (i))
Offside Front Drive shaft joint constant velocity boot severely deteriorated (6.1.7 (g) (i))
Was used daily until mot expired, belonged to my mom who bought something newer. My son was planning on building a track toy out of it but has changed his mind now. Clutch on way out as biting point very high now. Needs a good polish and clean inside. Only asking £200 for it, car is located in Farnborough, Hampshire/Surrey borders.
Any questions please feel free to ask, zero74494658zero3
gav
