Paul
Jan 11, 2021 22:12:18 GMT
This could be my next project (so hush hush), most recent MOT fail is on a couple of bearings, bulbs and this: Umm...what is it? Not an ARB drop link? Major worry or just something that needs worn out and replaced? I'm waaaaay out of my comfort zone on this one ☺️
Jan 11, 2021 22:25:51 GMT
(a) A steering linkage component with:
(i) relative movement between components which should be fixed (ii) excessive movement between components or likely to become detached
That's the manual code wording, it's likely to be something on the steering rack, or pitman arms if it's old enough to have idler arms etc.
Paul
Jan 11, 2021 22:57:26 GMT
Cheers - dropped off to the garage tonight, they didn’t tell me if they’d managed to MOT it but obviously just before closing they did. I’ll see what they have to say.
dragon
Jan 12, 2021 11:09:01 GMT
Check the registration number online as the system may have updated.
Jan 12, 2021 12:13:11 GMT
It depends on the testers interpretation of what a drop arm is. To me a drop arm (pitman arm in American) comes off the steering box to the centre link and tie rod assy. Once When I was on an MOT refresher course the DVLA instructor called the steering arm (arm that connects the track rod end to the suspension upright) a drop arm which had most of us confused. In your case it sounds like the idler arm is fubar but whatever it is get it changed.
Last Edit: Jan 12, 2021 12:13:50 GMT by timbo1956
Paul
Jan 12, 2021 17:45:50 GMT
Cheers all.
Turned out to be the steering idler arm that was wobbly. I've ordered a recon from eBay that should be here soon!
