Jan 10, 2021 15:45:59 GMT
Good afternoon
I need to replace some battery leads on a 40 year old vehicle so they are likely to need to be made to measure.
As it is not used much I would like to incorporate some sort of battery isolator.
Can anyone recommend a suitable supplier - preferably online please?
Jan 10, 2021 16:30:05 GMT
Last Edit: Jan 10, 2021 16:32:57 GMT by colnerov
Jan 10, 2021 16:52:27 GMT
What tools do you have available? I've made literally hundreds of battery cables, welding leads etc. buy the wire you need and the connectors, either fill them with solder and install like that or buy a hammer crimp tool and just give it a tickle with the persuading stick.
I've crimped them in a vice. Just use a ball bearing in a nut (to stop it flying out) and gently squeeze.
slater
Club RR Member Number: 78
Jan 11, 2021 11:54:55 GMT
Vehicle wiring products are decent enough suppliers. As mentioned you can buy all the cables and fittings and make your own.
