Dec 20, 2020 23:42:09 GMT
Last Edit: Dec 20, 2020 23:52:00 GMT by Woofwoof
Dec 21, 2020 11:59:11 GMT
looks like a bearing has spun on it possibly, have you tried the bearing for fit?
Dec 21, 2020 12:13:26 GMT
looks like a bearing has spun on it possibly, have you tried the bearing for fit? Yeah the bearing race had excessive play and was moving on the stub axle. The new bearing fits without issue.
lrman
Dec 21, 2020 13:58:12 GMT
As long as the new bearing doesn’t have play on the stub then it will be fine. The bearing runs on its own inner race so the surface of the stub axel isn’t going to make a difference just the ovality. I would fit the new bearing.
Dec 21, 2020 14:45:02 GMT
As long as the inner race has no play on the stub axle, I'd just fit the bearing.
Dec 21, 2020 15:36:13 GMT
As already said, bolt it up and try it, I’d check for play after fitting the wheel and before you drop it back on the ground, it’ll be more obvious if there’s a problem by using the wheel as leverage
Dec 21, 2020 17:37:34 GMT
Thanks everyone. I guessed it would be but it's good to get second opinions.
Happy Xmas one and all.
Dec 21, 2020 17:46:16 GMT
As long as the inner race has no play on the stub axle, I'd just fit the bearing. How do Simon, good to hear from you. A bit strange about the bearing, couldn't hear any noises even off boost. I only found the bearing issue as I'm fitting E-Class brakes, so I reckon I got lucky in not destroying the stub axle. Happy Xmas.
Dez
Club RR Member Number: 34
Dec 21, 2020 19:35:12 GMT
I’d be more worried about the seal surface than the bearing seat. Looks like it needs a good clean up or it’ll just destroy a new seal.
lrman
Dec 21, 2020 20:47:10 GMT
I would think as long as the seal is fitted to the same height as the old one so it runs in the same place in the centre it will be ok.
As long as the inner race has no play on the stub axle, I'd just fit the bearing. How do Simon, good to hear from you. A bit strange about the bearing, couldn't hear any noises even off boost. I only found the bearing issue as I'm fitting E-Class brakes, so I reckon I got lucky in not destroying the stub axle. Happy Xmas. Happy Xmas to you and family John. Your very lucky there with that bearing, I've seen them weld themselves to stub axle before!
