please recommend me your cheapest or free things to try and remove stubborn baked on brake dust from alloys, but as I post this I do feel daft as I don't have a pic to show of the wheels in question, I will be back tomorrow with that
the wheels are fairly modern, factory finish
ta
please recommend me your cheapest or free things to try and remove stubborn baked on brake dust from alloys, but as I post this I do feel daft as I don't have a pic to show of the wheels in question, I will be back tomorrow with that the wheels are fairly modern, factory finish ta I used Cillit Bang and a stiff brush on my e39 when I bought it, brought them up a treat. don't think they'd ever been washed. There will be some super duper stuff designed for it but I was working on a budget
Fair washing up liquid works great, for a proper wheel cleaner though Bilt Hamber is fantastic I got this stuff, done probably 16 wheels so far and loads left Amazon6
Last Edit: Dec 3, 2020 15:17:53 GMT by joem83
cillit and fairy sounds good
I used Cillit Bang and a stiff brush on my e39 when I bought it, brought them up a treat. don't think they'd ever been washed. There will be some super duper stuff designed for it but I was working on a budget +1 for Cillit Bang. Works a treat!
Last Edit: Dec 3, 2020 13:26:43 GMT by daklone
autosmart red stuff.
not cheap but you don't need to lather it on that much.
Last Edit: Dec 3, 2020 14:53:30 GMT by Woofwoof
I find Traffic Film Remover or Fallout Remover (Oxalic Acid) work well - just brush on, leave to soak for a while then rinse off.
Wonder wheels by car plan available in most car shops Great stuff
Last Edit: Dec 3, 2020 20:51:01 GMT by Mercdan68
e30ben
Oven cleaner, toothbrush hot water and scourer pads
Won't scourer pads scratch the clear lacquer coat?
cillit with some fairy worked a treat along with a wheel brush
I use cheap nylon-bristle scrubbing brushes a bit like these: and the cheapest Tesco value toothbrushes:
A quick spray and wipe over with furniture polish like pledge or mr sheen should help the brake dust stick to them less to make it easier for next time.
e30ben
Won't scourer pads scratch the clear lacquer coat? Non scratch ones that are used on. On stick pans may assist..... depends how bad the wheels are, use on the inside / hidden area first to get an idea of markings left?
I bought a set of these after seeing a few vids of them being used to scrub clean upholstery and discovered the toilet brush shaped one is excellent for cleaning wheels... www.ebay.co.uk/itm/333767444349
A quick spray and wipe over with furniture polish like pledge or mr sheen should help the brake dust stick to them less to make it easier for next time. I do something similar. I wax the wheels with a resiliant wax. After all, they will be hammered alot more than the bodywork of the car. This single change has made cleaning wheels much much easier. I may try Cillit Bang myself on the Mondeo wheels. They come up OK, but they are stained. They were never waxed however from the off, which I doubt has helped. You can see that the centres are slightly stained. The wheels were much worse before mind you. I used Bilt Hamber wheel cleaner which seems to be tough but also safe. Wonder Wheels IME tends to mar the surface slightly over time, where the wheel cleaner seems to keep things having their shine. Bilt Hamber was superb on my M3 wheels mind you, and I didn't think they could be coaxed back. The wheels were admittedly dirty in this shot, but there was backed on dust. About other products however -Fairy Liquid ; I've had good results with it stripping back paintwork before. Brake dust I can't remember. I rarely use it due to the salt content, and after all, salt and bodywork don't tend to mix. -TFR : I've had this produce good results, but never bring back wheels where the dirt is ingrained into the paint if that makes sense. The Mondeo has that issue, but also my 944 did. On the latter, I used to on occasion use Eastern European car washes. I know I know.... When it was for a little too long (and it wasn't that long) it left a staining on the bodywork, almost as if the water droplets had burned themselves into the bodywork. Given it was a cold day (this time of year) that the car was washed I was pretty annoyed. After that, I've never used TFR on cars again. On cars with anodised trim (my Mondeo, all Mercs since the Stroke 8s at least, VW Passats), it seems to attach the anodising, even if not left on for long. That leaves you with trim that's very hard to get right again. After all, anodising is a funny thing, regarding its durability but weakness too. If it does that to trim, it can't do much good on suspension components, bare metal items and places where the bodywork is chipped etc.
Oven cleaner. leave for a few minutes and rinse off.
Billit Hamber wheel cleaner is brilliant. Well worth a purchase
Billit Hamber wheel cleaner is brilliant. Well worth a purchase Yup, it worked wonders on mine. Some stubborn staining it can’t remove but it doesn’t seem to mar the surface. I may try some of the other remedies next time as the wheels don’t have much value
