Nov 26, 2020 21:42:10 GMT
Came across this recently, by chance.
If you start with episode one, seems like just another rusty old Triumph rebuild..... with extra rust.....
Then around episode 10 the goal posts get moved..... quite a way....
This is episode 16 - the most recent at time of posting.
Pity (or maybe just as well) the parts they are using are not readily available this side of the pond
Nick
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Nov 27, 2020 16:29:36 GMT
I agree. I'm already eyeing up the next project once the locost is finished (its barely started) and the thought of an LS is immense. Sadly, the availability here just makes it prohibitive.
brc76
Nov 27, 2020 17:08:47 GMT
I also had been watching this, it's mission creep, binky style.
It's too bad I can't put LS engines in my suitcase each time I come over to England!
Last Edit: Nov 27, 2020 17:09:33 GMT by brc76
bstardchild
Club RR Member Number: 71
Came across this recently, by chance. If you start with episode one, seems like just another rusty old Triumph rebuild..... with extra rust..... Then around episode 10 the goal posts get moved..... quite a way.... This is episode 16 - the most recent at time of posting. Pity (or maybe just as well) the parts they are using are not readily available this side of the pond Nick The only video stuff I tend to watch is Binky but this was really good - OK I did find the introduction recap at the beginning of every video slightly irritating but it's a small point
ToolsnTrack
Homebrew Raconteur
Came across this recently, by chance. If you start with episode one, seems like just another rusty old Triumph rebuild..... with extra rust..... Then around episode 10 the goal posts get moved..... quite a way.... This is episode 16 - the most recent at time of posting. Pity (or maybe just as well) the parts they are using are not readily available this side of the pond Nick The only video stuff I tend to watch is Binky but this was really good - OK I did find the introduction recap at the beginning of every video slightly irritating but it's a small point Ahem... we don't do recaps
