gezzard
Club RR Member Number: 69
Mystery switch in my Allegrogezzard
@gezzard
Club Retro Rides Member 69
Seems to have a picture of a pedal on it, I've looked in the handbook and tried to Google it but I don't know what it is, do any of you? L Oh, and it's a Vanden Plas1500 Automatic, if that helps. Fingers crossed 🤞
Last Edit: Oct 9, 2020 14:13:58 GMT by mrbounce
Hi, I think the pushing of it is to test if it works.
Colin
gezzard
@gezzard
Well, I've given to a push, aaaand nothing! Oh well at least I know what it is now, thanks chaps.
Yep, fitted to lots of Leyland cars. Push to test the bulb is working, depending on the car it will warn of either low fluid or an imbalance in pressure across a dual circuit system, or both.
Rich
Club RR Member Number: 160
Mystery switch in my AllegroRich
@foxmcintyre
Club Retro Rides Member 160
Hmmm, I can see a photo I uploaded, I'll try again. Yea, I could see there was an attachment but at the time neither my phone or pc would load it. As stated, with the ignition in ‘run’ you press it and it should illuminate to indicate your bulb works.
Last Edit: Oct 10, 2020 8:00:40 GMT by Rich
