slater
Club RR Member Number: 78
Wiper motor ideasslater
@slater
Club Retro Rides Member 78
Sept 28, 2020 8:24:48 GMT
Any ideas with this one?
I am putting a wiper on my vapour blast cabinet. I'm after a wiper motor which gives approximately 90-120degrees travel. Any longer is no good. Ideally it should be a fairly compact rear type with the wiper shaft coming stright out (I guess the taper the arm goes on is fairly standard)
It seems most rear wiper motors give closer to 180degrees travel. I think I might need somthing from an older car where the rear wiper was offset to one side maybe...?
Any ideas what I can punch in ebay or anyone got one sitting about spare? It's been a right faff finding an arm and blade short enough.. now no wiper motor I can find works either 🙄
Much love.
Sept 29, 2020 0:48:31 GMT
What about a headlight wiper motor arm and blade ? Much smaller and less sweep. Graeme Johnson
ChrisT
Club RR Member Number: 225
Wiper motor ideasChrisT
@christ
Club Retro Rides Member 225
Sept 29, 2020 5:34:46 GMT
Some vans with double rear doors have rear wipers, something like that would only have about 90 degree sweep.
lilbob
Sept 29, 2020 6:07:59 GMT
Early land rover or split screen Morris minor maybe
I was thinking as it's a smaller screen split in 2 the sweep area isn't as big
slater
@slater
Sept 29, 2020 7:41:19 GMT
Yeh I was thinking an old remote style lucas one would do it but it would just look cumbersome.
I think I might have a walk around the nearest car park and see what i can see.
Sept 30, 2020 12:12:47 GMT
Have a look for tractor wiper motors, a lot used to cab mounted above the screen and around the sweep you're after.
A quick look on eBay also shows up generic ones for jeeps and off road buggys etc with a 110deg sweep for about £25. They even have built in switch on the back of the casing which might make the installation look neat.
2p2g1m
Sept 30, 2020 20:27:06 GMT
MK2 Golf rear wiper motor may suit you. It doesn’t move to many degrees and is compact.
voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
Wiper motor ideasvoodoo57
@voodoo57
Club Retro Rides Member 137
Yeh I was thinking an old remote style lucas one would do it but it would just look cumbersome. I think I might have a walk around the nearest car park and see what i can see. Try a lucas type, same as the A40, they done a 1 and 2 speed i think?
