Danny
On your screen
So I’m helping a mate do a conversion on a MK5 Escort van that started life as a diesel and now need some advice on the fuelling side of things the donor car was a MK5 Xr3i
Work done so far
2.0 Zetec enging and box fitted
Subframe, brakes, steering and suspension
Full wiring loom and dash refitted
The donor car didn’t have a pump in the tank it had already been removed but the car was running fine just rotted
Anyway, I’ve managed to get a petrol van tank without the pump so my question is what pump do I need to get that will fit this tank? Also, what fuel lines do people use on the van conversion? or is it a case of using the car lines and adapted to fit the van?
Any help would be appreciated
Cheers
zeberdee
Club RR Member Number: 2
Last Edit: Jul 8, 2020 12:23:56 GMT by zeberdee
Danny
On your screen
Thanks mate will message him 👍
I have a brand new pump here I bought but didn’t need as I found one at my pals garage I fitted a petrol tank to my diesel van when we done the zetec conversion Just the fittings on the pipes will need altering to fit the pump I have , it’s new still in the box pm me if your interested Cheers Danny
Last Edit: Jul 8, 2020 14:25:56 GMT by Mercdan68
And we used all the original lines I know your local to me Danny So if it helps £30??
Last Edit: Jul 8, 2020 14:28:25 GMT by Mercdan68
Danny
On your screen
Hi Dan,
Thanks for that it sounds like a piece of cake, will speak to my mate tomorrow who’s van it is about your pump, sounds perfect to me Yes, not too far ss easy to collect 👍
Danny
On your screen
And we used all the original lines I know your local to me Danny So if it helps £30?? Hi Dan, Just spoke to my mate about the pump and he wants it, do you have a number i can pass on? Cheers
Pm sent fella
Cheers Danny picked up Told your pal to let me know if he needs anything else to let you know Thanks Dan
I so need a personal shopper !
Danny
On your screen
Cheers Danny picked up Told your pal to let me know if he needs anything else to let you know Thanks Dan Ok many thanks Dan will be in touch and thanks for your help
Two Dans had Two Vans both went too slow. So without much fussing but plenty of cussing. They now have much more go!
Danny
On your screen
Lol
