Déjà vu... My very first car was a green 1.0L pre-facelift K11. I had the bumpers and bootlid smoothed, badboy bonnet, Cobra bucket seats and a set of 15" alloys. All was well until an RTC ended its life. Here's a photo of it in its prime I then moved on red 1.3L facelift which I owned for 5 years. This was my first 'full' build, the parts list is faar too long to list. In the end the clutch needed changing,cross member replacing and it needed a respray. Approaching 21 I wanted something quicker, thats when my attention turned to MX5s. The car received two magazine features, Total Nissan and Banzai Magazine Me and Lu (my other half) were chatting awhile back, talking about how much we missed the red Micra, how we wanted a car that we could (ab)use and not worry about getting scratched or dented. We found this 2002 Facelift Facelift K11, 998cc with a whopping 58bhp of untamed power (sarcasm). Being a Vibe trim its extremely basic, I'm not even bothered about the manual windows, tin top roof, no AC or anything else Overall its in pretty decent condition for 65k miles. The odd scrape, dent and mark. Some attention will be needed on the N/S RR arch as it's bubbling and heading towards the sill corner. The sills themselves and cross member are very clean which is a bonus. Although don't let the photos mislead you, the car is very pink It serrrriously needs lowering, mainly to reduce the horrendous body roll.
The first thing to do was to get it MOT'd, despite having nearly a month left I wasn't going to take any chances especially as alot of people are using the extended 6 months as an excuse to sell 'a good car'. Its a good job we did!
It failed on a track rod end, how it was still attached is beyond me. The inner sills both sides at the rear didn't welding too which wasn't an issue. Unable to do the welding I got it booked into my usual garage and got them to look at a couple of other issues I discovered when viewing the car.
The engine has an intermittent noise coming from the pulley area, sounded like a bearing on a pulley or water pump. With the the alternator belt removed the noise stopped so that was an easy diagnostic. Found a refurbished unit on eBay for £67 posted so that's a job for today (10/06/20)
Another issue was the clutch pedal being sticky and hard to push down. The seller mentioned the clutch being replaced approx 6 months ago, if that was me I would have taken it straight back to get sorted as it just isn't right. Having spotted the clutch cable was new, I wondered if the seller got ripped off and the garage only replaced the cable not the clutch, but there's evidence of the box being split.
The cable still had some adjustment, with that wound in as much as possible the pedal felt much better but still wasn't 100%. A friend suggested greasing the spring on the pedal arm, so I did and its spot on now! I did the other 2 while I was there for piece of mind.
One other minor issue was the interior heater blower only worked on speed 3 and 4, an £8 heater resistor off eBay soon fixed that
Jun 18, 2020 20:02:21 GMT
On the previous K11 I had some DTM mirrors fitted with what seemed to be one of the very few sets of base plates in existance. Having failed at finding them again I was on the hunt for alternatives. I came across a website which had a large selection of photos of mirrors and I came across VW Golf MK3 base plates which looked very similar. A friend had some M3 style mirrors and baseplates for a Golf, a quick test fit confirmed I could do something with them to make them fit. Abit of cutting and drilling and these were the results. Not a 100% fit but they're pretty close Finding some wheels that suited the car and being cheap seemed a tricky task. Doing a search on google,Facebook and the forums I came across some examples of BMW E30 14" bottletop wheels. I managed to find some locally for a total sum of £40.00, winner! A friend is currently sand blasting them then I can get them painted. Originally we thought white, but the spoke design would make keeping them clean a nightmare. The second choice was a gun metal grey, silver may be too plain/boring. Also found a set of 185/55r14 locally from a friend which saved us alot of money With all of the parts finally arriving, it was time to finally lower the car. Alot of people tend to go with Corsa B coilovers, but I didnt like the idea of drilling/filing the top mount holes on the car. So we went for the Daewoo Matiz set up instead. This compromises of Mk1 Daewoo Matiz 35mm lowering springs (rear only) on front K11 shock absorbers. The rears are Corsa B KYB shocks with 're-engineered' K11 lowering springs. I've read of people complaining about the rear springs being too soft if you use the originals, thats why we went for lowering springs instead. I ran into some issues along the way, sadly it wasn't all plain sailing. Firstly the driver side inner CV joint popped out. Secondly the upper nuts on the rear shocks wouldn't undo due to the centre spinning in the locking grips. In the end I cut the shock to get them out, made abit of a mess in the boot (oops). The last thing was the collar from the original panhard rod was seized on the car and took alot of grinding to get it right. Browsing through the Facebook pages and market place and I found a universal back box made to fit the K11. Being quite impatient I drove almost 2 hours to go collect it. Being a second facelift the rear bumper doesnt really have an exhaust cut out, so the backbox sits lower than the others which made fitting it that little bit more tricky. But we got around it and my bumper cutting even surprised me! I also made a start on painting the chrome and faded plastics, starting with the bonnet grilles and fog light covers.
mada01
Jun 18, 2020 21:58:16 GMT
Enjoyed your old build so will be keeping an eye on this
roarz
little under powered cheap cars are the best. My granddad has a exactly the same car for his customer car at his garage, pinkish in colour, basic interior etc, i tried getting it off him for years but he wont budge with it.
I have a Vauxhall Agila I'm doing some little mods to at the moment, i fricken love it, bit hard to get parts for but you "make them fit". look forward to see what happens with the micra
riggs
takes me back, my dad had several micras from from 1990-2002 models, I remember getting a brand new T plate red 'tempest' model. Last micra he had was a 2002 turquoise, cant remember the model name but it was electric windows and remote locking!
absolutely cracking cars - looking forward to the build
hoodedreeper's K11 MIcra v3fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
In for updates, I only came across the Total Nissan issue with your original K11 micra in the other day whilst re-organising my shelves. I do love a smoothed boot lid and bumpers. Are you leaving the VIBE sticker on the bootlid and adding an accompanied vibe audio install?
Jun 20, 2020 19:11:55 GMT
Unsure on the sticker, it'll probably be removed at some point No audio install i'm afraid
milk
Jun 22, 2020 21:15:29 GMT
is the stickers from the original going to be replicated on this one. reminds me of your skyline design
Jun 26, 2020 21:07:49 GMT
The Skyline graphics are abit of a homage to the first K11. Unfortunately they won't be making a return on this one. I feel if I did i'd be comparing it too much and it wouldnt be the same. Although I am using alot of inspiration from it for this build
Jun 26, 2020 21:08:06 GMT
Jun 26, 2020 21:33:52 GMT
That looks great on those wheels, understated and cool, and quite motorsporty, but they remind me of the Longman Mini 1275GT wheels Mabie its an idea for a colour scheme? Some great mods going on already.
Last Edit: Jun 26, 2020 21:35:01 GMT by bmcnut
Jun 26, 2020 21:54:18 GMT
They remind me of Compomotive TH and Renault Speedline Turbines. I agree they do have a motorsport look to them which I like alot.
I am toying with colour schemes, mainly something that works with the faded red paint as I really don't want to respray the whole car. I've got a look/style in mind which is slowly coming together
milk
Jun 26, 2020 22:09:40 GMT
What a difference the paint and wheels made. watching this with interest
vitessetony
Club RR Member Number: 114
hoodedreeper's K11 MIcra v3vitessetony
@vitessetony
Club Retro Rides Member 114
Jun 26, 2020 22:19:40 GMT
Super build so far, I'm warming to these little K11's. Bookmarked.
Going to follow this one. I've always loved these and Me and hannah got her sister to buy one as her first car. When I was in the UK last year I borrowed hannahs brothers k11 Micra to go to RRG. Fantastic fun little car. I've been after one for ages now and might just buy one when I take the Imp off the road to swap the engine.
Sadly there aint as many in NZ. They are called a March here- pretty much all Japanese imports. Most are 4 door autos :-(
They're very fun cars once they're lowered, not so much in stock form lol
They have a pretty large following world wide, the March parts are very sought after here in the UK
markbognor
Club RR Member Number: 56
hoodedreeper's K11 MIcra v3markbognor
@markbognor
Club Retro Rides Member 56
Jun 27, 2020 12:58:04 GMT
Going to follow this one. I've always loved these and Me and hannah got her sister to buy one as her first car. When I was in the UK last year I borrowed hannahs brothers k11 Micra to go to RRG. Fantastic fun little car. I've been after one for ages now and might just buy one when I take the Imp off the road to swap the engine. Sadly there aint as many in NZ. They are called a March here- pretty much all Japanese imports. Most are 4 door autos :-( That's quite ridiculous that most of them in NZ are Japanese imports, yet they were actually imported to Australia from the UK production lines.
Jun 30, 2020 10:44:43 GMT
Yeah that seems crazy! I wonder how popular they are in oz? They are holding there value here. Just good cars. Bloody amazing how cheap they are in the UK!
