vulgalour
Club RR Member Number: 146
1980 Austin Princess 1.7 HL manual
Mechanical Stock engine, gearbox, brakes, etc.
Cosmetic - Interior
New red carpet Re-dyed door cards and seats from black to red Dashboard panel re-veneered in zebrawood Some trim edges given additional chrome/silver to standard
Cosmetic - Exterior Front and rear bumper removed Front valance smoothed out, indicators/sidelights relocated Sealed beam headlights upgraded to halogen Front numberplate relocated below front valance, using original bumper mounted brackets Rear numberplate frenched into rear valance Bumper mounting pressing smoothed out Austin A30 sidelights repurposed as high level indicators on C pillars, lenses tinted amber Rear lights are two pairs of 1964 Ford Galaxie light units, frenched into the rear panel Honda Acty door mirrors
Volvo 240 wheel trim rings C pillars painted satin black, vinyl removed Unipart aftermarket boot spoiler
Future plans Lotus Elite wheels Different door mirrors Hidden front indicators and sidelights Finish the paint Take some better pictures.
Last Edit: Jul 10, 2020 22:47:58 GMT by vulgalour
vulgalour
Various different wheel options and mirrors have been on the car over the years, I do intend to go back to the Lotus alloys eventually. Fake moon wheel trims are nice to swap in and out now and then.
vulgalour
First outing since rebuilding the head. Sporting early hub caps for a change.
vulgalour
Worth mentioning the Unipart boot spoiler, a very rare accessory and very appropriate for what this car is. I'll be redoing it in beige so it blends in better than the black.
Jul 31, 2020 16:41:37 GMT
such a strong body design, would be good to see it lowered.
@ CRX_IN_SCOTLAND
shin2chin
Looks great, really suits the mods. My uncle had a brown one with biscuit interior when I was in primary school.
vulgalour
Easy to do by letting the fluid out, but then it drives like absolute garbage. It does sit a bit lower than standard, unless it's a hot day and then it sits at about standard height. The joys of fluid-and-gas suspension.
logicaluk
such a strong body design, would be good to see it lowered. Easy to do by letting the fluid out, but then it drives like absolute garbage. It does sit a bit lower than standard, unless it's a hot day and then it sits at about standard height. The joys of fluid-and-gas suspension.
is it possible to put a spacer under the spheres to lower the ride hight? Dan
vulgalour
Not really because of the way they're aligned in relation to the rest of the suspension. If you want it to still handle and ride even moderately well it's not an easy system to lower. Also, when you do start lowering them you start getting lots of clearance issues with the wheels and inner arches, not to mention how quickly the sump gets too close to the floor. Then there's the other issue that the ride height is affected by ambient temperature, you can gain and lose quite a bit depending how hot or cold it is.
Best to leave it as BL intended in all honesty. Pumping it up to a slightly lower pressure, or letting out a little fluid is about the best compromise you're going to get and you can only realistically lower them about an inch or two if you want it to still be a nice car to drive.
On top of all that, Hydragas/lastic cars that have been lowered pretty much always look like the suspension is broken and since there's still people who remember these cars bumbling about with broken suspension, that's not a good look.
