jamesd1972
Club RR Member Number: 40
May 23, 2020 15:24:42 GMT
Hi good people of RR.
We have success that with new points and and coil the new 2.3 petrol in the LR burst happily into life !
Less successfully it then revs its nuts off with no choke and no throttle open... I can get it to slow down by putting my hand over the carb to restrict airflow but have obviously got something going on.
Its an early 110 engine with a Weber DMTL carb and manifolds.
Anybody know this carb and able to give some pointers ?
Thanks
James
Last Edit: May 25, 2020 20:45:51 GMT by jamesd1972
jamesd1972
May 23, 2020 15:25:59 GMT
Have a moody night shot ! James
jamesd1972
May 23, 2020 15:31:16 GMT
James
May 23, 2020 16:30:07 GMT
Is the float stuck, or a needle missing/damaged? Silly question- there is/are jets fitted to the carb aren’t there? Butterfly stuck/bent etc?
May 23, 2020 17:18:44 GMT
It must be getting extra air from stuck spindle or choke mechanism.
If its twin choke are both butterflies fully closing?
May 23, 2020 17:43:28 GMT
Any missed or open ports on the inlet manifold?
jamesd1972
May 23, 2020 17:57:33 GMT
Thanks for the thoughts, will have another look to make sure all is shutting off. Slightly resigned to taking it apart again but sounds like air source is the key. James
jamesd1972
May 23, 2020 18:17:53 GMT
Just had a quick play, looks like the primary butterfly isn't fully closed at zero throttle. Blanking off the breathers etc. that aren't yet plumbed in made no odds, had to put hand over primary to stop reving too high. Other than that no nasty bangs or noises from the engine so still progress ! Will take carb off and report back. Thanks James
slater
Club RR Member Number: 78
May 23, 2020 21:06:07 GMT
There should be idle speed adjustment on the linkage somewhere.
jamesd1972
May 25, 2020 21:11:28 GMT
I am officially a numpty. Completely confident that we had done the throttle cable set up all correct I didn’t double check. Guess what it was ? Cable too tight… Anyway I think we must have set it when the mechanism was sticking slightly open. That’s my excuse and I’m sticking to it. I’ve already hung my head in shame but at least I’ve admitted it ! Been struggling with the mojo on this recently so very happy with the below. Sorry for wasting your time but the support was appreciated. James
jamesd1972
May 25, 2020 21:15:10 GMT
Oh and if anybody can point me in the direction of how to tune this carb that would be good - don't have a manual for it yet. James
I’ve got a Weber tuning manual, but it’s for aircooled VWs so doesn’t have your carb, I think it shares parts with the dcnf, but that’s just a twin choke, there is tuning and setup info for a 32/36 dfv but not sure if that’s any use (I’ll hold off posting any photos, but happy to if you think they may be helpful) And there is no shame in getting it wrong, most of us have been there.... I like to think of it as a learning opportunity, which is good because I then get a lot of opportunities to learn
