jmsheahan
Club RR Member Number: 121
Manifold studs - which to usejmsheahan
@jmsheahan
Club Retro Rides Member 121
Feb 20, 2020 12:40:32 GMT
Hi all, I'm about to bolt my stainless 4 branch manifold back on and am unsure which are the best studs to use. I have a choice of the stock steel studs or stainless studs. They will be going into an alloy head and I will use copper nuts to fasten them down. I was planning to use stainless in the hope they wouldn't rust but I've heard a few things about them being unsuitable for use in alloy? Any help appreciated
tristanh
Routinely bewildered
Feb 20, 2020 12:51:34 GMT
I use steel studs, with copper nuts, and find that works. A lot if stainless is soft.
Feb 20, 2020 17:39:38 GMT
The problem is galvanic corrosion which is when disimilar metals are put together and the transfer of electrons causes one of the metals to in effect, decompose. True, mild steel and aluminium will have a problem like this, but not as bad as aluminium and stainless steel. As an aside, some stainless steels are not as strong as high tensile steel and may snap under certain circumstances. Brass nuts would be better than copper. Assembling everything with a high temperature copper grease will help taking it apart again though it may smoke for a while!
Manifold studs - which to usestealthstylz
@stealthstylz
Club Retro Rides Member 174
Feb 20, 2020 18:01:56 GMT
I usually use OEM ones of whatever thread I need and the type where they have something to wind the stud in with. Ford do quite nice ones with a male torx on the end.
jmsheahan
@jmsheahan
Feb 20, 2020 18:56:57 GMT
Hmm sounding like it may be best not to use the stainless then and smother the OEM ones in high temp anti-seize.
Would be nice to have some with torx on the end, sadly the standard VW ones don't.
Thanks for the help all!
