Hi all
I just bought a Suzuki Jimny automatic. .
It runs great above 1100 RPM. but below this it is missing a bit/ runs rough.
Now this little 4WD has a push button selectable (is this a word??) transfer case. The selection of low/high 4WD is vacuum operated. This doesn't work as
there is apparently a vacuum leak. I haven't looked into this yet. I only picked up the car a few hours ago.
So, I can't select 4WD as there is a vacuum leak.
Could this leak also be the reason for the rough idle?
Thanks a lot for thinking with or for me.
Cheers
Cheers
