Feb 13, 2020 20:16:01 GMT
Is it a bad idea?
They're a lot quieter than a generator
I have a complete 1.2 Punto I could use
Would it be more fuel efficient?
My generator puts out 3.5kw, how do you get a car engine to do similar or more?
Would you need a governer to operate as a generator?
Is it too simplistic to think this is a good idea?
Milord
Feb 13, 2020 20:29:31 GMT
bookmarked, as I have some extra engines lying around and have been playing with the same idea but lack electrical know how
Currently: BMW E46 320i Touring BMW E34 525TDS Touring VW T3 panel van 1.6d Opel Kadett C1 Caravan 1.2 Fiat 411R
Feb 13, 2020 21:16:50 GMT
slater
Club RR Member Number: 78
Feb 14, 2020 13:59:04 GMT
Someone asked this a while back and basically no it wouldnt be as good as a proper generator engine. Especially a petrol.
Feb 14, 2020 14:16:24 GMT
Ok,
Got anymore info on that?
What thread was it in?
There was a recent thread about using a generator for welding but that doesn't seem to be it
93fxdl
Enter your message here...
Feb 14, 2020 15:35:27 GMT
May have been urban myth, but years ago I was told of some flats powered by a Renault engine,running on gas, driving a generator for electricity and the cooling water and exhaust running through heat exchangers to warm the building. it was not enough power at maximum demand so would draw from the grid and put back any surplus at times of low demand. Ttfn Glenn
melle
South West
It'll come out in the wash.
Feb 14, 2020 16:17:25 GMT
Ford Cologne V4 engines (as found in Saabs, Matras and European Fords) were used for all kinds of industrial applications, amongst others coupled to generators. I have a few manuals for this engine on my website.
Last Edit: Feb 14, 2020 16:18:07 GMT by melle
Phil H
Club RR Member Number: 133
Using a car engine as a generatorPhil H
@philhoward
Club Retro Rides Member 133
Feb 14, 2020 18:56:37 GMT
Many engines have “industrial” versions but usually very different to their car counterparts, usually the carb is set to be speed controlled (so a mechanically coupled throttle) and the camshaft is usually different to set it to run best at a constant speed (usually 1500r or 3000rpm so the motor attached to it will generate at 50Hz).
melle
South West
Feb 14, 2020 19:23:40 GMT
The industrial Ford Cologne V4 was identical to the car engine, but depending on application often had a Hoof governor fitted on the standard FoMoCo carb.
Feb 15, 2020 16:10:39 GMT
Wasn’t there a programme a few years ago with Robbie Coltrane and featured uses of a 350 Chevy engine to power everything from air raid sirens to air con plants? IIRC they ran on lpg? Of course I could be lying.....
Feb 15, 2020 17:00:18 GMT
I would recommend using either something running on LPG (a bottle can be used but is expensive) or an old diesel running on something other than pump fuel.
Feb 15, 2020 18:11:27 GMT
It was quite common for air raid sirens in America to be powered by V8 engines. Can't see the point if you're just using the alternator as the generator though, might aswell just run whatever you want to do off the car you're in.
generallee
Feb 15, 2020 19:05:45 GMT
So, to summarise this thread. Car engines; may or may not be any good for generators. Great for air raid sirens.
Last Edit: Feb 15, 2020 21:07:33 GMT by generallee
Darkspeed
Club RR Member Number: 39
Feb 15, 2020 19:29:26 GMT
May have been urban myth, but years ago I was told of some flats powered by a Renault engine,running on gas, driving a generator for electricity and the cooling water and exhaust running through heat exchangers to warm the building. it was not enough power at maximum demand so would draw from the grid and put back any surplus at times of low demand. Ttfn Glenn No myth at all - many flats and offices have CHP (Combined Heat and Power) one of the best small units was powered by an industrial Toyota engine - very efficient system. The small units that the company I worked for sold started with a VW engine and then changed to Toyota as the service requirements were far superior. Micro CHP whereby the majority of homes have a small generator as part of the gas central heating boiler has been around for decades but never really caught on - Honda invested heavily in the tech and --- we are getting way off topic.
Feb 15, 2020 19:42:03 GMT
Its what most hybrids do, I'm trying a PHEV transit this weekend, it uses a 1.0 3cyl fiesta engine coupled to a generator which charges the battery and the Van is driven by an electric motor.
A car engine will work fine, You just need some sort of governor and a very good cooling pack. Modern engines are pretty efficient anyway, An older engine developed for the job will probably be more efficient though.
Feb 15, 2020 19:44:18 GMT
They work fine but you need a fair bit of torque to keep up with the instant demand. If your'e generator is loud you can extend the exhaust, I know mine has a flange as the tailpipe so I can add on a longer length of pipe.
Feb 15, 2020 20:20:25 GMT
Volkswagen flat fours were/are used as generators and sold in a different format as a bespoke industrial powerplant .
Plenty of US V8's used as well in agriculture for irrigation , again with appropriate mods whatever they may be .
TessierAshpool
Club RR Member Number: 168
Feb 15, 2020 21:58:12 GMT
Not seen one done with a car motor, but saw this cute little 12v generator a while ago made from a strimmer motor and a motorbike stator. Looks very easy to replicate:
slater
Feb 17, 2020 12:43:16 GMT
I think what you need to understand is a engine for a car has vastly different requirements than an engine for a generator. For example the car engine works over a wide speed range where as a generator ideally keeps a constant speed at all loads. It has to react to load quickly (so yes it needs to be governed) to avoid a drop in frequency and power output as the electrical load increases.
A proper generator engine is going to have a vastly different cam profile for example. A diesel is going to be more efficient for the usual diesel reasons. People are right there are industrial stationary versions of vehicle engines but they are more then just bolting a truck engine down to a stand if you know what I mean.
It's likely that a car engine used for generation would need to be much larger and because of that much less efficient than an optimised unit.
