Dec 30, 2019 19:32:29 GMT
Hi, I'm struggling to remove the pistons from some 16p girlings - any ideas? They're some Ebay specials and looking at them the pistons look new but I can't get them out!
Dec 30, 2019 19:48:09 GMT
If you have access to compressed air put a wooden stopper (thin enough to stop the pistons flying away!) between the pistons , put air line in the hose feed and try blowing them out.
ChrisT
Club RR Member Number: 225
Girling brakesChrisT
@christ
Club Retro Rides Member 225
Dec 30, 2019 19:49:12 GMT
Compressed air blow gun to the brake fluid inlet and block of wood between the pistons so they don't pop all the way out.
Can be done with the right attachments to a foot pump if you've not got compressed air.
Dec 30, 2019 20:08:08 GMT
Or a spare brake hose and a master cylinder to generate hydraulic pressure, much higher pressure and a lot safer than pistons flying on compressed air.
Dec 30, 2019 20:16:41 GMT
Or use a grease gun.
Dec 31, 2019 11:45:19 GMT
Another vote for the grease gun, nice and controllable but a bit messy clearing up after
Dec 31, 2019 13:23:41 GMT
It took some work but I got them out, fortunately the compressor could do it!
Dec 31, 2019 14:53:15 GMT
I was going to say +1 for the grease gun, but I’m late to the party as usual However I’ve made up an adapter with a grease nipple one end, and a pipe fitting the other, works great on cortina masters and slaves too, particularly clutches Well done for getting them out, they can be a pig!
Girling brakesChasR
@chasr
Club Retro Rides Member 170
Cleaning grease out after a grease gun however can be a pain . Compressed air tends to work IME or using the car itself ; this is easiest done with a second person however.
Girling brakesaccord83
@accord83
Club Retro Rides Member 51
I adapted an inlet fitting that then fit my foot pump, I have used it on numerous occasions to move stuck pistons. Only I cannot find it since I moved into my new garage! Time to sort out another this year.
I did it! I editing the whole process if anyone is interested in how to do it
Ooohh! Shiney! Nice job there
I did it! I editing the whole process if anyone is interested in how to do it Yes please !
Jan 10, 2020 20:17:50 GMT
Fitting the seals without getting my hands in the way was tricky!
Any questions just ask!
Jan 10, 2020 21:46:15 GMT
Might be talking out of my backside, but is rubber grease compatable with brake fluid? When I’ve built callipers I’ve always used new brake fluid as lubricant
Jan 11, 2020 12:16:32 GMT
Good question, the seal kit comes with it and the stuff I had been reading suggests it.
I would have used brake fluid but I haven't done the brake lines yet so insure how long they'll be sat - nothing extreme but could be a month or 2
Girling brakesChasR
@chasr
Jan 13, 2020 18:15:35 GMT
Red rubber grease is compatable.
It's also way easier to install the seals over using brake fluid IME.
Jan 14, 2020 12:47:49 GMT
good to know Chas as I did find it tricky
Jan 14, 2020 13:30:57 GMT
Not sure it actually makes any difference, but I fitted the seals, and then the pistons, before fitting the dust covers Didn’t find it that easy either, but the dust covers were secured by snaprings
