tristanh
Routinely bewildered
Nov 12, 2019 13:18:47 GMT
A friend is working his way through tidying up his 305 van, they were a very popular workhorse here in Ireland. He wants to drop it about 2 inches on wide steels, anyone any info on springs for the rear? It's a strange setup, the spring is massively long and stiff when uncompressed.
Nov 12, 2019 13:56:28 GMT
chop it or get a shoter one made
tristanh
Nov 12, 2019 19:19:58 GMT
Easier said than done. Like how much do you cut off, or how do you spec you want for a shorter one?
slater
Club RR Member Number: 78
Nov 13, 2019 17:23:47 GMT
Well most people just chop a bit and see what happens tbh.
If you really wanted to get more technical you could try and calculate it from the spring rate, spring ratio (if any), corner weights of the car etc. If you get someone to make you a set of springs they will probably do it for you to some extent but you would have to supply at least some of the data I guess.
In summary fit coilovers lol
