E reg
Car has been used for shows
1987 built 33 year old!
You wouldn't think it,its in outstanding condition for age. Its had a bear shell respray jacking points and sills replaced
All the interior is present and clean parcel shelf has no 6x9 holes in it!
Only changes to the interior are radio has been changed afm and boost gauge on a pillar
External
Speedline wheels have been fitted due to the big brake upgrade so the standard wheels will not fit over them,standards are included with tyres.
Suspension has been lowered
Under the bonnet.
Red hose kit
Large alloy fmic hidden behind grille and bumper so it still looks standard
Large alloy radiator with internal oil cooler
Larger t28 turbo from rover tomcat fitted carb rejetted afm installed and rolling road setup
No dump valves or waste gates
The dump on the turbo is load enuff!
Anti perc removed wiring is still insitue
Custom exhaust
Never uses oil or coolant no smoke on start up or boost
Always warmed up and cooled down correctly
Some other spare parts included
Any question just ask viewing and any inspections are more than welcome ...
Would not take much to have back to 100% standard
External
Under the bonnet.
Red hose kit
Custom exhaust
