Sept 19, 2019 13:15:02 GMT
This is the dual circuit brake master cylinder I want to used on the Corsair they were fitted on export Corsairs but not UK ones. So Its a mod to improve the breaking system. My is I know all the threads are imperial on this bur what are the thread sizes for the fittings and what do the coloured caps signify? Any and all sensible info gratefully accepted?
Last Edit: Sept 19, 2019 13:15:16 GMT by peteh1969
Sept 19, 2019 13:47:47 GMT
Hi, A point to note is that the pipe ports are on the 'wrong' side, it will make installing the fittings difficult because it will be very close to the inner wing. You could try getting some Banjo fitting conversions to ease the situation. Land Rovers have the same type M/C with the ports on the other side in the require imperial flavour, although making up metric / imperial pipes is not difficult.
Colin
Edit: Sorry forgot to add the thread sizes are 3/8" unf and 7/16" unf for 3/16" pipe, however be aware some 7/16" fittings are for use with 1/4" pipe. Available on ebay and all good suppliers.
Last Edit: Sept 19, 2019 14:04:13 GMT by colnerov
Sept 19, 2019 14:18:23 GMT
Colin
I intend to use Banjo's for the very reason you mentioned.
Now no joke being a child of the 1970's and not fully understanding imperial thread sizes is the green plug 3/8" size or the red one I know all the piping is 3/16" Dia?
I would sooner ask now.
Sept 19, 2019 16:20:38 GMT
Hi, They're just transit dust plugs, I don't think the colours for anything more scientific than different size holes.
Yes, it looks like the red is the conventional 3/8" unf and the green is 7/16" unf.
Colin
Last Edit: Sept 19, 2019 16:23:34 GMT by colnerov
Sept 19, 2019 16:28:55 GMT
Hi, Are you using a shuttle valve with it?
Colin
Sept 19, 2019 16:51:38 GMT
Side A will go to the front brakes and b will feed the rears, with side a going through the Servo before reaching the brakes Colin
Sept 19, 2019 17:11:07 GMT
Hi, Plumbed through a shuttle valve if one circuit fails the good side pushes the shuttle across to seal it off so there's no fluid loss and you still get a good pedal on the good side.
Colin
slater
Club RR Member Number: 78
Sept 19, 2019 18:07:01 GMT
They are the same thread no? 3/8unf I'm betting
The plugs are meaningless
Just measure them rather than relying on what people on the internet say. As this thread seems to prove atleast half of them are going to be wrong.
Sept 19, 2019 18:21:26 GMT
peteh1969 where did you get the master from? Ive been toying with using one on my MK2 cortina, same as you, only fitted to export models. TIA
Sept 19, 2019 20:23:32 GMT
From a chap in Ireland He originally got it for a Mk1 Escort but never used it.
Sept 21, 2019 11:23:09 GMT
Ah ok, thought you might have found a supplier, thanks anyway
Sept 21, 2019 13:32:12 GMT
Ok all I need some help on car builder site I have found 3/8" and 7/16" banjo bolts but I cannot find the banjo fittings with male or female 7/16" threaded ends so I can connect my brake pipes directly to the banjo fittings or any female 7/16" connectors for the pipe to go into any Ideas?
One thing I don't want to do is mix metric with imperial threads.
Sept 22, 2019 12:59:38 GMT
Where are you based? Locally to me I've got a couple of pipe and hydraulic specialists who are quite happy to help with pipe sizes and fittings, just take the cylinder in
Sept 22, 2019 18:32:15 GMT
Sept 22, 2019 23:15:20 GMT
Thank you Colin
Those will be helpful.
jamesd1972
Club RR Member Number: 40
Sept 23, 2019 20:22:50 GMT
automec.co.uk/Found these guys massively helpful - watch the flare type as well as the thread. James
