1989 VW T25 Reimo camper van ,1.9DG petrol ,4-speed
This is offered for sale as a project or parts for converting your existing van.
it has no MOT and has been sat on my drive for the last six years.
it starts and drives but will require some recomissioning and a thorough check over of all the mechanicals.
as you can see from the pictures it will also need some welding in the usual T25 areas.the main areas i can see are as follows.
both front cab steps
the fuel filler panel and B-post
the area under the o/s sliding window and sill to side panel seam
both lower quarter panels and inner rear arches
o/s/r roof gutter (i have sealed this up as a temp measure to keep the water out)
there may be more but the underside looks pretty good and the van is very straight otherwise
i do have a repair panel for the n/s/r quarter .
now onto the good bits
full Reimo conversion ,a high quality German company ,similar to westfailia
two berth rock and roll bed with lap belts
two berth roof bed
electrulux 3-way fridge
gas hob and grill
zigg 240v hook up and 12v split charge system
sink and fresh water tank
240v lighting and 12v LED lighting
240V night heater
fold down digital tv DVD player
digital twin battery read out
passenger swivel base
mx5 front seats (will need some universal runners to mount them)
tow bar
sony head unit and 6x9 speakers.
if your handy with a welder this should be a cheap and easy project for someone.
viewing welcomed and recomended .
obviously due to no MOT and being laid up for so long it will need to be recovered from my house in north essex.
open to offers but i wont give it away as its worth more in parts.
two berth roof bed
gas hob and grill
240V night heater
tow bar
