jamesd1972
Club RR Member Number: 40
Aug 15, 2019 12:09:03 GMT
OK from a garage clear-out I've gained the below cans of grease. I've done a quick bit of googling but come back more confused. I have a suspicion that the Alvania 2 grease is a MS3 equivalent so I can use it for wheel bearings and the like but it would be good to confirm. Not at all sure what the Alvania 3 grease can be used for though. Photos on post below. Thanks James
Last Edit: Aug 15, 2019 12:14:23 GMT by jamesd1972
jamesd1972
Aug 15, 2019 12:13:21 GMT
Better to use them than just throw them out. Cool old tins anyway. James
Last Edit: Aug 15, 2019 12:27:01 GMT by jamesd1972
jamesd1972
Aug 15, 2019 12:27:39 GMT
Ritchie
Club RR Member Number: 12
Aug 15, 2019 12:37:41 GMT
Best I could find,
Shell Alvania Grease RL2 A medium consistency grease designed, mainly, for general industrial lubrication. Ideal for centralised lubrication systems operating at normal temperatures. Shell Alvania Grease RL3 A medium/hard high performance industrial grease, particularly recommended for the lubrication of electrical motor bearings.
I would say they would be just fine for most automotive uses.
Now replaced by Shell Gadus grease.
sowen
Club RR Member Number: 24
Aug 15, 2019 17:15:28 GMT
Looks like a lifetimes supply of bolt antiseize there!
Aug 15, 2019 18:08:46 GMT
MOS2 is molybdenum-disulphide , cv joints etc.
The other one looks like general grease (if a bit dry!)
jamesd1972
Aug 15, 2019 20:33:25 GMT
Looks like a lifetimes supply of bolt antiseize there! A happy find if I can use them ! James
jamesd1972
Aug 15, 2019 20:34:46 GMT
MOS2 is molybdenum-disulphide , cv joints etc. The other one looks like general grease (if a bit dry!) Yes, its a bit better below the crust ! Pretty sure the Land Rover won't mind the MOS2 on its wheel bearings ! James
