MiataMark
Club RR Member Number: 29
Jul 25, 2019 10:08:10 GMT
Got an issue with my MX5 which I find hard to explain, basically when you accelerate there is a lot of what sound like exhaust blow noise and it feels like there is resistance to acceleration. The closest I can come to is that it is similar to when I had EGR issues on my diesel Alfa.
No fault codes show on the admittedly basic diagnostic port.
The car did initially fail an MOT on erratic idle that the garage put down to the Idle Speed Control, a good Italian tune sorted that out. I've taken the air Valve off and given it a good clean which I think has improved things. Which potentially leaves the Idle Speed Control Valve (which is expensive and should show as a fault on the diagnostics as it's electronically controlled, or there is a sensor).
There is another worry, I've never been that happy with the cooling system on the car and the water level does seem to drop, could there be a HG issue? I haven't had time to either check the oil filler and do a compression check. Can't see any oil in the water but it's so rusty that I'm not sure you could, needs a good flush through.
Anybody with MX5 engine experience got any hints...
Last Edit: Jul 25, 2019 11:45:22 GMT by MiataMark
Jul 25, 2019 11:19:48 GMT
With all these things its best to get back to basics:
Does it have compression Does it have a clear air path (air cleaner, catalyst or muffler blocked, ducts collapsing, throttle fully opening, air leaks post MAF) Ignition- do all the plugs look OK and the same, coil packs and leads could be breaking down. Fuel - is the fuel pressure OK, does it drop at high load, is the filter blocked, colour of plugs will also tell you if it is running weak or rich.
These are in that era when the on board diagnostics was pretty useless and testing parts on the bench is not easy, diagnosis largely falls down to replacing parts, if you can find someone with a similar car swapping things like MAF, coilpacks etc is an easy way to rule out components without spending a fortune.
MiataMark
Jul 25, 2019 21:25:39 GMT
Been to a local garage (that did the MOT) diagnosed as miss-firing probably ignition. I've ordered new plug leads and plugs as I was going to renew them anyway.
Rich
Club RR Member Number: 160
bad running uder accelerationRich
@foxmcintyre
Club Retro Rides Member 160
Jul 25, 2019 21:52:13 GMT
Been to a local garage (that did the MOT) diagnosed as miss-firing probably ignition. I've ordered new plug leads and plugs as I was going to renew them anyway. Plugs and leads were moderately common on the MX5, the one I bought for the engine misfired from cold until it had been driven for a good few miles, new plugs and leads sorted it a treat.
MiataMark
Been to a local garage (that did the MOT) diagnosed as miss-firing probably ignition. I've ordered new plug leads and plugs as I was going to renew them anyway. Plugs and leads were moderately common on the MX5, the one I bought for the engine misfired from cold until it had been driven for a good few miles, new plugs and leads sorted it a treat. Good to know, I was going to change them anyway so will be good to see if it makes a difference. I'll do compression check as well, if I can find my gauge.
Aug 13, 2019 21:52:50 GMT
bad running uder acceleration.
So the cars not Moo vin too well?
"Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity." Albert Einstien
Jensen Healey Supercharged MX-5 drive train
Ford Transit V8 Gone to new pastures
Buick 1949 Restomod
bad running uder accelerationChasR
@chasr
Club Retro Rides Member 170
Is it misfiring or just making alot of noise instead of moving along?
If it's running smoothly, I'd say its a blocked catalytic converter or a fuelling issue.
MiataMark
Is it misfiring or just making alot of noise instead of moving along? If it's running smoothly, I'd say its a blocked catalytic converter or a fuelling issue. It was fixed with new leads and plugs.
