ckerr
Jun 24, 2019 10:36:14 GMT
So it was my birthday over the weekend and ive been going on about new tool boxes for ages... The wife surprised me with some of the big DeWalt TSTAK boxes they are awesome!!! big enough to fit my 3 drills and all there accessories in one box. Id like to line them with some thick foam, with drill shapes (for example) cut out so I can then layer the box to make the most use of the space. A layer would consist of a 4-5mm piece of ply with foam glued to it, so it would be stiff enough to lift, possible with some sort of handle at each side. Does anyone know a cheap way to get the foam? I had originally though house insulation but its all foil backed now and starts at about £30.
kabman
Jun 24, 2019 11:25:41 GMT
I got some gardening kneeling mats from a market. They were 2 for a quid.
Jun 24, 2019 11:55:04 GMT
Yoga mats from pound shops
ckerr
Jun 24, 2019 15:44:45 GMT
Was thinking something a bit thicker... 3 inches possibly. To allow a to sit down into it. Yoga mat could be nice on top for a splash of colour lol.
Jun 24, 2019 16:49:55 GMT
Was thinking something a bit thicker... 3 inches possibly. To allow a to sit down into it. Yoga mat could be nice on top for a splash of colour lol. You could always use like 3 sandwiched together. Cut the drill shape out of top two & leave bottom solid, would work great
Jun 24, 2019 18:15:44 GMT
As an aside, I don't recommend used yoga mats...
simes
Jun 24, 2019 18:16:59 GMT
Google diced foam.
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
Jun 24, 2019 18:45:57 GMT
As an aside, I don't recommend used yoga mats... Why not? You could always simmer them in water for a while & then you’ve got a clean mat & some stock for a nice homemade soup 😉
Jun 24, 2019 19:06:47 GMT
As an aside, I don't recommend used yoga mats... Why not? You could always simmer them in water for a while & then you’ve got a clean mat & some stock for a nice homemade soup 😉 Lycra soup?
Jun 24, 2019 19:22:56 GMT
Why not? You could always simmer them in water for a while & then you’ve got a clean mat & some stock for a nice homemade soup 😉 Lycra soup? Mmm...
Jun 25, 2019 10:22:05 GMT
There's are things called Yoga blocks which might work - about 40mm thick But what you're really looking for is 'Flight Case Foam' - as in the stuff Photographers / Hit-men / DJs use - search on ebay - you can buy it by the yard.
Tool Foamfr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Jun 25, 2019 10:22:59 GMT
pluck foam or DIY it with expanding foam
Jun 25, 2019 13:27:04 GMT
Kaizen foam is the stuff you require. Company in USA make it. Hard to get here and slightly pricy but the ultimate foam. Take a look on YouTube and see
