Jun 17, 2019 18:49:20 GMT
Help! Does anyone know where to find the drain holes on a latest version Vauhall Corsa? The carpet on the driver's side is sodden, front ad back, but not the passenger side or under the seat. I presume rain is getting in through somewhere then has no way of getting out. In compensation for this dull modern car question have some retro Vauxhalls.
rickygolf83
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Jun 17, 2019 19:23:38 GMT
Think its the scuttle panel drains that get blocked on these
Jun 17, 2019 19:26:57 GMT
Corsas have a history of letting in water. Remove the wiper arms and plastic scuttle trim to gain access to the top of the bulkhead where the drain hole will be. Also check things like grommets, pollen filter, heater blowers. Good luck.
Jun 17, 2019 21:09:52 GMT
The Corsa c has a plate in the bulkhead in front of the driver and the seal on it fails, the panel isn’t very expensive but it’s a bit long winded to change, this could be your problem !?
Rich
Club RR Member Number: 160
Jun 17, 2019 22:13:11 GMT
The Corsa c has a plate in the bulkhead in front of the driver and the seal on it fails, the panel isn’t very expensive but it’s a bit long winded to change, this could be your problem !? A corsa C isn’t the latest model though and the current model isn’t based on the C platform.
Jun 17, 2019 23:11:56 GMT
Sorry completely missed that bit, doh !!
Corsas have a history of letting in water. Remove the wiper arms and plastic scuttle trim to gain access to the top of the bulkhead where the drain hole will be. Also check things like grommets, pollen filter, heater blowers. Good luck. Thanks, I'll try this today fingers crossed.
Jun 18, 2019 16:32:01 GMT
Can’t answer your question but I had same thing on a 5 series BMW. I just got a fine screwdriver & bosted a hole in the floor.... job done
andyborris
Jun 18, 2019 17:37:21 GMT
Can’t answer your question but I had same thing on a 5 series BMW. I just got a fine screwdriver & bosted a hole in the floor.... job done Proper mechicanicaning this.
Jun 18, 2019 18:21:46 GMT
Can’t answer your question but I had same thing on a 5 series BMW. I just got a fine screwdriver & bosted a hole in the floor.... job done Proper mechicanicaning this. Dead right, why complicate things 😉
Jun 18, 2019 18:34:36 GMT
*%(&&%)($I!ing modern cars! Cant get the plastic trim off from the base of the screen because it's not attached with normal screws - I think it's clipped on somehow, and it's sealed to the windscreen. If it was my own car I'd still give it a go but it's actually my parents so I'm wary of doing some irreversible damage, so they're calling in the pros (£££). Thanks to those of you who tried to help anyway.
