Great work you've done there, it's really coming along. I always enjoy up-dates on this. Shame about the wheels not having the right stud pattern. That said, I quite like the original "washing machine drum" ones. They're kind of 1970s-British- Leyland-industrial-chic. Once reconditioned they'd look pretty cool, maybe with a slightly wider tyre if there's something that would fit. Thanks for the reply bud glad you're enjoying the build! Yeah I was a bit gutted if I'm honest as I was looking for a set for quite a while. I see where you are coming from with the standard wheels they're just not to my taste just fancied something different from the norm however I did see a banded set for sale that looked quite nice. That looks awesome, maybe when it finished I can show my wife the pictures and convince here to let me rebuild mine 😁 I will try my hardest to convince her A set of five 13x5j Cosmic Mk2s in need of a refurb which the seller assured me came off a Spitfire. However when I came to test fit them this afternoon they didn't fit turns out the stud pattern is wrong 4x108mm which i think may be Ford? Gutted as you can imagine as I don't think I'll find another set anytime soon so I was wondering if anybody else has fitted wheels with a different stud pattern to their car using adaptors if so I'd be interested to know. If you want to use these wheels lookout for a pair of Caterham alloy front hubs as they fit the Spitfire stub axle and have the ford pcd. The type you need are the standard ones not the uprated version. Brian. Here :- caterhamparts.co.uk/hubs-and-bearings/116-hub-aluminium.htmlI had read somewhere about that conversion pretty sure Canley classics sell something similar. I did think about getting some stud adaptors but wasn't so keen on that idea, wheels are currently for sale to make way for something that'll fit without modification.
1975 Triumph Spitfire 1500
Small update, The big day finally arrived on Wednesday (4/11/20) That's right its back at home for the 1st time in over 2 years! After pushing it off the trailer I wasted no time at all and started putting a couple of bits back on to make it look a bit more like a car again starting with the rear lights, the chrome on the originals were quite badly pitted thankfully I managed to pick up these NOS units off of Ebay a couple of years ago fitted with new gaskets, Nice, next up washer jets and wiper linkage so nice to be working with new/refurbished parts, little things make the biggest difference in my eyes, after this I fitted the heater valve and coil on to a new stainless bracket, also fitted the little rubber drain flap that cost £5.50! As mentioned previously the Cosmic Mk2s I brought didn't fit (still for sale if anyone is interested) and looking at it the original wheels were really letting the car down quick order later and we have my 2nd wheel choice nice set of JBW Dunlop D1 reps wrapped in Yokohama Blue Earth tyres and they have completely changed the look of the car Well Chuffed. only a small update but things are moving forward and hopefully more progress will be made this weekend.
Last Edit: Apr 30, 2021 22:37:10 GMT by cjl1281
teaboy
Make tea, not war.
I like Dunlop D1s, it will look great on those.
Nov 22, 2020 20:29:40 GMT
Bit of an update on the progress I have made over the past week or so. Pretty much finished fitting up the bulkhead now just need to fit the starter solenoid, make some battery cables along with making another brake pipe for the brake master cylinder as I manage to kink it (numpty) Here's how things are looking The eagle eyed among us may have noticed that a new wiring loom has also been fitted, although there was nothing obviously wrong with the old loom some of the connections looked a bit crispy so for my own piece of mind thought it was best to fit a new 1. For anybody thinking about buying a new loom I can highly recommend seems to be made to original spec and quality is great. I have trial fitted my dash to make routing the loom easier. very thankful that I took reference pictures now. running the rear loom through the hole in the sill was a bit of a fiddle but managed it in the end and wired up the rear lights 1 thing I am a bit unsure of are these 2 wires here, thinking maybe cig socket or map reading light? Next up exhaust. 1 evening after work I jacked the rear of the car up and set about trying to fit the exhaust starting at the manifold working my way back I manged to get the system loosely fitted in place Having a bit of difficulty getting the rear box lined up properly it's sitting too high on the nearside and i can't get the offside any higher as the tailpipes hit the bodywork pretty sure the pipe welded on the box that goes onto the mid section isnt bent correctly I'll figure it out eventually. Then come the moment i have been dreading so far... installing the windscreen. Rewind to last Friday (13/11/20) me and a former work colleague made an attempt to fit the screen, however things didnt go quite as we planned to cut a long story short the screen put up a fight and the seal tore... F*ck. fast forward to this morning armed with a new Coh Baines seal me and my mate gave it a go and after an hour of bashing, pulling string and swearing Success! after this i promptly fitted the wipers I then dug out the dash top cleaned with some Autoglym vinyl and rubber care before fitting it to the car Thankfully the vinyl is in good condition so that's 1 less thing i have to worry about. Still need to fit the speedo + Rev counter but the dash is starting to look more like a finished item. Arty shot because why not Thanks for reading
Last Edit: Apr 30, 2021 22:43:44 GMT by cjl1281
Nov 27, 2020 16:55:45 GMT
That's looking mightily pretty! Isn't it wonderful when everything starts coming together
Nov 27, 2020 17:33:54 GMT
Been a lurker on this forum for a while now but reading this post has encouraged me to register.
I bought a 1972 mkIV when I was 16 and spent a year rebuilding it ready for the drivers licence. Used it as my daily for years then went on honeymoon in it getting as far as Florence. Came back via Monaco, Nurburgring and Spa. Ended up keeping it for 10 years and reluctantly sold it to make way for an integrale.
Now, 30 years later I still remember my Spit fondly and would have another in a heartbeat. Still have the integrale though!
That's looking mightily pretty! Isn't it wonderful when everything starts coming together Cheers buddy too right it is soo nice to be finally bolting all the shiny bits back on. Been a lurker on this forum for a while now but reading this post has encouraged me to register. I bought a 1972 mkIV when I was 16 and spent a year rebuilding it ready for the drivers licence. Used it as my daily for years then went on honeymoon in it getting as far as Florence. Came back via Monaco, Nurburgring and Spa. Ended up keeping it for 10 years and reluctantly sold it to make way for an integrale. Now, 30 years later I still remember my Spit fondly and would have another in a heartbeat. Still have the integrale though! What a great story amazing how cars can play a big part in people's memories. Have you searched to see if the car is still on the road? Integrale what a car definitely on my bucket list.
Last Edit: Nov 30, 2020 0:13:47 GMT by cjl1281
More progress has been made this week. Managed to find some suitable bolts for the starter solenoid which enabled me to get it all wired up, bulkhead is now pretty much finished just need to make up a brake pipe to replace the 1 I kinked. tried to keep the wiring as neat as possible but there's only so much you can do. Next up glovebox. I wanted to get this fitted as I always intended on fitting an isolator switch and I thought this would be the best place for it. Purchased from a well known supplier that rhymes with Dimmers I cant say i'm impressed with the quality had to trim the corner a bit and redrill some of the holes as they weren't quite in the right places. Never mind all sorted now and isolator installed. Nice to know that the car has some form of security now. With this out of the way I finished off the dash by fitting the speedo, rev counter and speedo cable (my poor fingers) also wired up the wiper switch. Hazard switch not installed just yet for testing purposes. then the time came to stick the battery on and see what happens, wipers, heater blower and rear lights all working with no fires, even the engine was turning over... result. With my confidence levels high I decided to splash some fuel into the float pots, rig up a temporary fuel supply as I'm still trying to source a pick up pipe for the fuel tank and see if she'll fire into life. Started 1st time... Get in. Still needs tuning up and properly setting the ignition timing but not sounding too bad. Few niggles to sort exhaust still needs messing around with to get it sitting right, temperature gauge isn't showing a reading, I put the feed wire straight to earth and the gauge works thinking the sender isn't working so even more to think about there. That pretty much brings us up to date. Thanks for reading
gazzam
Looking very good. You should be well pleased. Great that it fired up first go, very satisfying.
Looking very good. You should be well pleased. Great that it fired up first go, very satisfying. Thanks bud, yeah very happy its starting to all come together it has come a long way but still plenty to do
Dec 21, 2020 17:45:43 GMT
It's been a little while since the last update so I think it's time to fill you guys in on the progress that's been made. After the success in the last update we did have a little scare as the engine started to make a rattle when held at around 2k RPM however this thankfully clear after the engine fully warmed up and hasn't been back since. I'm assuming the oil hadn't quite managed to get through all of the journals until warm. Panic over I moved on to installing the new fuel tank (which surprisingly fitted quite well) and plumbed it all in, splash of some super unleaded and fired it up. Unfortunately whilst waiting for her to warm up in order to set the ignition timing i notice fuel leaking from the top of the float chamber on the front carb, engine was running rough so switched it off and popped the cap off to have a look. After speaking with a mate I decided to ditch the Gross valves for some proper needle valve which sorted that issue out allowing me to set the timing and tune up the carbs now she's running really well and I'm able to drive it in and out of the garage... Bonus no more pushing! Next up interior, a few weeks ago 2 very large packages arrived 1 including all of the bits to recover the seats, new door cards etc and the other included a newton commercial carpet set unfortunately I'm lacking photos as I got a bit carried away but here's the result. Go figure Just need to screw the side and rear boards in. I'm planning on reupholstering the seats and arm rest over Christmas so watch this space and I promise to take more pictures.
Dec 23, 2020 13:25:02 GMT
cjhillman
Dec 23, 2020 17:26:20 GMT
I'm impressed with the restoration of you car! lovely stuff! Can I ask where you had your loom made up? My Dad has a 1500 Spitfire that has a bit of a rats nest of wires plus my Capri has a few issues on the bonnet side.
Dec 23, 2020 18:00:48 GMT
I'm impressed with the restoration of you car! lovely stuff! Can I ask where you had your loom made up? My Dad has a 1500 Spitfire that has a bit of a rats nest of wires plus my Capri has a few issues on the bonnet side. Thanks bud much appreciated hard work is finally paying off. I brought the wiring loom from Autosparks they make looms for all different makes & models at a reasonable price too lovely quality.
Dec 23, 2020 18:09:03 GMT
lovely job you ve made of that hats off to ye
Hmmm in need of a 2nd option here folks unfortunately the engine rattle has returned. I removed the engine from the car in 2018 just before it went away for all of the bodywork. It was fully stripped down to a bare block where it was discovered that it had already had a rebore and crank grind, old shells were in good condition as was the crank so I put new shells in that matched the old 1s. I honed the cylinders to take the glaze off and fitted new pistons/rings, unleaded conversion, new chain + tensioner, oil pump, gaskets and seals. We had the engine running in the chassis on a few occasions with no issues all sounding OK and it was still OK when I wired it all up and had it running on the key until a few days later when this rattle appeared, hold the revs up and you can hear it rev the engine and you can hear it as they are coming back down. Interestingly this went away but now it has come back and I'm completely puzzled as it sounds like a chain rattle but it seems more central in the engine maybe a little end? Thoughts and opinions welcomed.
Last Edit: Jan 4, 2021 16:37:08 GMT by cjl1281
I can't hear anything in the 2nd video, in the first one it sounds like either a cam follower sticking it maybe piston slap?
Depending on how bad it is it might be worth waiting until you can drive it round the block to get more of an idea about it.
I can't hear anything in the 2nd video, in the first one it sounds like either a cam follower sticking it maybe piston slap? Depending on how bad it is it might be worth waiting until you can drive it round the block to get more of an idea about it. The 2nd video isn't the best but can hear the noise around the 5 second mark. Interestingly my mate thought it could be cam related but he wasn't so sure himself. I have driven the car around my close as we have an island type thing in the middle wasn't so noticeable underload that I could hear. Should also mention no difference with the clutch down.
Sounds like valve train to me. Maybe check the tappets again and run with the top off to see if all the push rods are turning.
Also have a listen around the distributor base
Nick
I was thinking valve clearances originally however I only readjusted them a few weeks back. Just had a little listen around using my trusty long screw driver and have identified the noise is coming from where pictured below can hear a very distinctive tick tick through the screwdriver. Could this be a sticking cam follower as homersimpson suggested? If so how can I fix this? Cam followers were new along with camshaft.
