1995 Citroen Zx estate 1.9td Bosch Diesel Pump
hello.
For sale is my lovely Citroen zx estate. Possible future family situations force me to update and get iso fix points.ive owned this car for nearly 4 years now wish and since ownership I have serviced or changed anything that needed doing.
MOT - 3rd September 2019
currently on - 97591 miles (won't go up as its off the road now)
New cam belt at 70k
new genuine old stock psa water pump
new radiator
new clutch
new clutch fork and bushings
new handbrake cables
new front disks and pads
new rears shoes and cylinders
new front lower arms, drop links, tie rod ends, wheel bearings, front legs.
regular oil changed every 3k or so.
two new front tyres about 1k ago.
sweet homemade roof rack
tow bar
Most of this was not needed but I got the garage to be able to do this kind of work so I believe in just getting it done before it goes later on. my new 320d e46 within 2 weeks has had new front wings. oil filters, clutch, flywheel, prop coupling, gearbox oil etc. if you keep onto of things then cars look after you.
The best part about the little Citroen which is actually the top spec aura model. alloy wheels, electric front windows and sunroof etc. Is the Bosch diesel pump. which means it can be run on straight vegetable oil in the summer months. 80 is pence a litre from Costcos I believe. a full tank usually sees me 400 odd miles.
so the bad points of the car are asthetically its not the greatest dinks and stone chips everywhere, but she isn't a rust bucket. mechanically she is great never let me down in the 30k I've driven her for.
drivers door lock just went (£20 of eBay for a lock kit) I go through the passenger.
rear windows don't work (the cables snapped as they got a weird gearbox cable system)
Price - £500
Located - Warlingham (near croydon south London)
07867492754 - best thing to do is call or message me. I'm slow on the forums.
got a lovely little box trailer aswell that could go with the car in a deal. just needs a light board as I haven't got round to sticking some lights on it.
hello.
New cam belt at 70k
new radiator
new clutch
tow bar
Price - £500
