So I have two welders, a Clarke 151te and a Sealey 180. I don’t need two. They’re both in good working order and do roughly the same job, but I only use them every now and again.
What would you keep?
The only benefit to the sealey is it accepts larger cable reels.
The reason I ask is that I need to make space but I also intend to do a eutotorch conversion and I only have one eurotorch. I always presumed Clarke were generally a better make.
What’s the opinions?
