Hi All,
Just had mate on the phone he has had issues with his 10 plate SWB Renault traffic van.
Was driving and oil pressure fault came up on dash along with loss of power. Took it to the garage and they replaced the vacuum pump. Van was up and running for about three weeks then....(all fluid levels correct) Same issue Oil pressure fault light, followed by loss of power and engine running really rough and cut out. Van recovered.
Garage then replaced an Oil Pressure Valve, still wont start.
Mate is now picking van up as fed up, they are removing the new fitted Oil pressure valve replacing the old and he wont be charged.
So oily finger types.... what is up? Any pointers would be appreciated.
Also ..oil pressure valve...is that the oil pressure switch?
I have no fault codes until we pick van up and if it will work with my elm code reader I will get some codes up.
Cheers
BM
Cheers
BM
