polo6n1600i
All I need is WD40 & Duck tape!
Dec 17, 2018 17:41:26 GMT
Ok so this is an odd/great story & I thought you guys would be interested! I'm a VW guy and have been since I learned to drive & bought my first Polo - but my dad bought a brand new Austin Maestro VDP (A802KNB) when I was 5.... To say the R series engine with fuel issues, talking dash & plenty of rust repairs kind of stayed with me. On Facebook I saw a Montego 1.6 LX for sale for £500 & took a shine to it, but being close to Christmas I could afford it! A few weeks later the same car popped up as part of a Bonus Ball at £9 a ticket - so I thought sod it & bought a ticket - number 41! A couple of days later I get a message from the owner to tell me the car was mine. Relaying of the car by a few friends has been organised & the car is being shipped from Cambridge to Birmingham (done), then Birmingham to Crieff (arranged for 5th/6th Jan) Going to try and make it watertight first, then tend to the rust and replace a few parts. Upgrade the brakes, coilovers and MGF 15" wheels & generally enjoy it until the MOT is due in July. After that who knows!
2002 Vw Polo 1.9 TDI sport - Daily Diesel 2006 Vw Passat 3.2 v6 estate - family wagon 1990 Rover Montego 1.6 LX - Project 41
polo6n1600i
Dec 18, 2018 19:42:05 GMT
Haynes Manual & Rove workshop manual both acquired. Hoping to sort out a few parts over Christmas for it and get started after the new year. Got a day booked off to get up to Narven to rummage over a couple of Montegos!
Dec 18, 2018 19:48:02 GMT
What a brilliant stroke of luck! Enjoy it sir!
Dec 18, 2018 20:26:59 GMT
Was selling these new back in the day, they were quite a good drive in reality. Looks like you got good value acquiring this one 😄
polo6n1600i
Dec 18, 2018 21:15:26 GMT
Project budget is £500... Not sure how long that will last as it needs a bit of work on the brakes. Then the rust (all cosmetic really - nothing needed done to the chassis)
Found some 16" MGF wheels locally, just refurbed with tyres & some 2nd hand Polo 6n coilovers to bash on it... And a Cherrybomb from my youth! 😀
richie
Dec 18, 2018 21:33:19 GMT
Result for that money, should be similar suspension to the Maestro so the Polo coilovers are easy to fit.
I think I just had to grind a bit of material of the fronts and open a few of the holes out a bit.
Hope you like rust..
polo6n1600i
Still cool for £9. Montegos and maestros do drive well. Much better than the Fords of that generation.
polo6n1600i
Dec 27, 2018 10:16:20 GMT
Genuine Rover Workshop manual sourced for £5 off ebay. Also looking at part numbers etc i should be able to use some Mg ZR sunroof drainage pipes to stop the sunroof leaking (there aren't any on it at the moment!) So far my essential list runs to the following:- Boot carpet complete Drivers side 1/4 window (mines cracked & will probably fall apart when removed to fix the rust) Roof lining inc all trim clips, grab handles & interior lights. Passengers side front electric window unit (complete) Sunroof switch & surround. Its off to the bodyshop as soon as I get the brakes serviced! Windscreen & all 3 rear windows out. Repair and repaint the apertures. Cut the lower skin off both front door and replace / repaint. Refit windows. Hoping for not much more than £500. But I think its worth doing it right once, then enjoying it for a while!
polo6n1600i
Jan 15, 2019 13:47:26 GMT
So things are moving forwards.. I took a trip up to Knaven near Peterhead to have a scavenge of another white LX Montego. I managed to get a rooflining biscuit (just needs recovered in new material & fitted), a sunroof drain pipe, a sunroof switch unit & a drivers side rear 1/4 window... All for £30! On my first drive i had a stone flick up and crack my screen too! Which sucks, but I have windscreen cover on the insurance, so they are going to take care of that! New water pipe to fit tomorrow - its damaged and leaks once its warm. And a Brand new SU carb to put on it (still in the original box!) - which should stop any fuel leaks!
polo6n1600i
Jan 21, 2019 10:34:03 GMT
40 hrs labour at approx £25 per hour for rust repairs and repaint..... Car booked in for Feb 25th! MG 15" Lattice wheels sourced, New Carb & Fuel pump. New water hose fitted and cooling system drained & refilled. Got electric windows to now sort & a good few items to service inc brakes, timing belt etc.... I'm hoping to have the whole thing finished by the summer! Wish me luck!
Jan 21, 2019 10:52:00 GMT
I was an Austin Rover mechanic when these were new. The Turbo model is PROPER fast but I love the fact you are saving this LX model. IIRC, I was forever changing the rubber cam cover seals!
polo6n1600i
Jan 21, 2019 12:41:45 GMT
Exterior will be as it left the factory. But under the bonnet maybe not so much!
Jan 21, 2019 13:57:37 GMT
Good on you for saving it - and the Bonus Ball bit had me laughing - a car for £9! I've a soft spot for these too; my dad had a B reg 1.6L in Gold, then replaced that with an E reg 2.0Si. The Si eventually got relegated to trailer hauling duties before coming to me as my then daily - I swear it got faster as it got older (probably as the rusting bits falling off made it lighter!). Terminal rust killed it in the end, well, that and spitting all it's oil out due to a blocked breather. Friend of mine used to work at Austin as an R&D engineer - they had great fun when developing the Montego Turbo as they stuck all the running gear in a beige shell badged as a 1.3L!
polo6n1600i
Jan 21, 2019 14:01:58 GMT
Well i was reading that the factory used the Montego as the test mule for the K series engine. So I know it fits.... I'll be getting at the parts together once the car is rebuilt (probably buy a full MG ZR & transfer most of the running gear over in to the montego shell) - should be able to get a full running scrapper for about £200-£300. A VVC 160/180 would be ideal!
norm75
Jan 22, 2019 20:34:05 GMT
Well i was reading that the factory used the Montego as the test mule for the K series engine. So I know it fits.... I'll be getting at the parts together once the car is rebuilt (probably buy a full MG ZR & transfer most of the running gear over in to the montego shell) - should be able to get a full running scrapper for about £200-£300. A VVC 160/180 would be ideal! probably teaching you how to suck eggs, but you do know the 180 was only available in the MG ZS and wasn't a k series 4 cylinder, but was the 2.5kv6 engine. Montego V6 would be cool though.
Jan 23, 2019 11:07:47 GMT
was the 2.5kv6 engine. Montego V6 would be cool though. its a deal
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Jan 23, 2019 23:04:27 GMT
Yep this floats my boat, watching with interest 👍
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Jan 24, 2019 12:57:59 GMT
Wow £9. If i may be nosey, where do you find such gambles to play? I wouldn't mind a flutter myself!
polo6n1600i
Jan 25, 2019 12:17:50 GMT
It was just on the Facebook owners club page that it popped up. Norm75 - yes but the K-series has also been fettled by Lotus & By Caterham to produce 180/190 & 250bhp in various states of tune! 5x 15" Maestro MG Turbo Wheels sourced! Sticking to Full LX interior & spec as far as I can - with the addition of some driving lights & Possibly a roof rack & Box paainted the same colour as the car (white on top & grey on the bottom). Wheels are getting refurbed in the same Grey as used on the lower section of the car too.... New fuel pump arrived along with various service parts from Rimmer Bros. Still need to get plugs, leads, oil filter, air filter, timing belt / water pump. Then onto the brakes! MGF 280mm conversion on the front with new rear drum & shoes. The Polo 6n coilovers (probably AP for a bit better comfort) & then finally a nice custom stainless exhaust.... I have the plan to get this thing all sorted for my 40th Birthday on the 10th of April....
