Nov 17, 2018 13:58:53 GMT
Around my barn in pitch black and i'd like a way of illuminating any scrotes which come sniffing after hours
i have in mind the kind of brightness from the typical halogen flood light but i have no mains power so thought about solar
I thought maybe £100 might get a half desent one but there is a lot of choice so thought i'd ask here for anyone who has one?
Nov 17, 2018 14:39:53 GMT
I think you will struggle to get anything combined to match a mains unit output wise, I tend to go for separates so if for example the PIR fails which they do you can just change that rather than the whole unit
Nov 17, 2018 14:48:08 GMT
thanks, can you explain what is meant by combined or separate?
I would have one with a solar panel on a lead as i need to leave it in the sun
Nov 17, 2018 15:28:15 GMT
Nov 17, 2018 17:09:49 GMT
Be interesting to see how it performs and lasts, normally I buy a light fitting, separate PIR and if its got no electric go for a car battery and solar panel charger and get all 12V stuff, works out more expensive but lasts longer in light output and life of the equipment
Nov 17, 2018 22:00:01 GMT
costco, around 40quid, has 3 banks of super bright led, that can be sperately aimed so you get a hell of a spread of bright light,can be set for various lengths of time, pretty big solar panel as well, it lights up our entire garden from the shed a the bottom of it
Nov 17, 2018 22:02:45 GMT
costco, around 40quid, has 3 banks of super bright led, that can be sperately aimed so you get a hell of a spread of bright light,can be set for various lengths of time, pretty big solar panel as well, it lights up our entire garden from the shed a the bottom of it Sounds familiar Is it anything like this?
Nov 17, 2018 22:28:20 GMT
costco, around 40quid, has 3 banks of super bright led, that can be sperately aimed so you get a hell of a spread of bright light,can be set for various lengths of time, pretty big solar panel as well, it lights up our entire garden from the shed a the bottom of it Sounds familiar Is it anything like this? yup! but cheaper in costco been up 2 years now an no problems
Nov 17, 2018 22:41:53 GMT
yup! but cheaper in costco been up 2 years now an no problems I assume you are a member?
Nov 18, 2018 10:47:30 GMT
Nov 18, 2018 11:21:28 GMT
I’d buy a light bar off eBay and a stand alone PIR and use a car battery. You can just put the battery on charge every few weeks.
Nov 18, 2018 12:05:56 GMT
Thanks, i'll keep those in mind
Nov 18, 2018 12:24:25 GMT
I’d buy a light bar off eBay and a stand alone PIR and use a car battery. You can just put the battery on charge every few weeks. Thanks, i wanted one which hopefully takes care of itself
Nov 18, 2018 17:52:43 GMT
yup! but cheaper in costco been up 2 years now an no problems I assume you are a member? actually I'm not, lol but went in with a mate who is!
