Replacing the rear brakes on my 1980 88", and noticed the rear wheels don't spin freely, taken drums off and still tight to turn, so its not the brakes binding.
Removed half shaft to check wheel bearings thinking they are too tight but they are fine as without the halfshaft in, the hub will turn nicely.
The handbrake/transmission brake isn't binding, and holding the rear prop and trying to turn that, is quite hard, so why is my axle tight??
Thanks
Thanks
