Badger
Sept 24, 2018 23:08:29 GMT
Hi all, I've put an AJ30 V6 engine in my kit car (from a 1999 S-Type Jag) but am having problems locating the engine number on the block (which I need for the IVA) - google is no help, can anyone point me in the right direction? It may be in the same location as the ST200\ST220\X-Type engines.
If it's only on a sticker I may be in the poo, as I painted the block!
beejay
Sept 29, 2018 20:10:05 GMT
This link shows where it is on the X type JaguarForum linkYou'd think it'd be the same on the S type, if not a search on JaguarForum may help
Badger
Sept 30, 2018 21:52:00 GMT
Cheers - I did find that and look there but couldn't make anything out... my fault for painting the engine I guess! Will have another proper look when I get back.
Badger
Update for reference: it is indeed on the bottom left of the engine, under the engine mount and just above the sump join. The reason I missed it before is because it's really, REALLY difficult to see properly! Ta for the help
