Sept 19, 2018 19:52:47 GMT
Looking at moon disc options for my VW Polo / 13 inch diameter standard steel wheels ? Saw a set on fleabay but looks like you need to take them off to inflate the tyres Any one with resourceful insight know of an alternative but still giving that moon disc look from other wheel hub caps Thanks in advance
Started out with nothing and have most of it left.
MR TIKI
TIKI,style from a different angle!
Sept 19, 2018 20:19:20 GMT
why not "Go with Moon"? they can be fitted straight to the rim using three self tappers and are easy to remove,it will not have adverse effects on tyre pressure when done right.how often do you envisage having to inflate your tyres and why? I've run Moons of differing sizes on my Imp including 13" that I sold on via RR to then be fitted on a Skoda and then a Polo pickup. I'm yet to find something that looks as good or better than a Moon when it comes to that "Moon disc look" Good luck Bryan
Last Edit: Sept 20, 2018 0:07:13 GMT by MR TIKI
Boldly driving faster than a tin worm can wiggle.
brc76
Sept 19, 2018 20:38:10 GMT
I ran the hubcap version that they also sell on my passat, was as simple to remove as a regular hubcap. I did lose one once though.....
Sept 20, 2018 7:36:11 GMT
I had a set of the push on ones, simple as that! As above I did loose one tho then when I found it it had been squashed
Sept 20, 2018 8:46:57 GMT
Ah never thought of self tappers / problem solved / thanks for common sense advice / appreciated
Sept 20, 2018 17:03:30 GMT
Just a question out of interest using self tappers / do they attach to outer rim / if so does that involve removing tyres or do you fit self tappers higher up on rim / great idea but a forum member who as done it is always best for knowledge or suppose could drill tiny holes in moon disc and use cable ties to prevent one being lost ?
Last Edit: Sept 20, 2018 17:35:07 GMT by Quasimoto
MR TIKI
Sept 20, 2018 20:17:05 GMT
Just a question out of interest using self tappers / do they attach to outer rim / if so does that involve removing tyres or do you fit self tappers higher up on rim / great idea but a forum member who as done it is always best for knowledge or suppose could drill tiny holes in moon disc and use cable ties to prevent one being lost ? the disc sits inside the outer rim,with the wheel laying face up I centred the disc then marked the three holes on the rim and drilled them out to the depth of the rim,because the holes are well below the seal in the bead wall it shouldn't cause you any issues.be careful to chose the right screw depth so you cannot do damage to the tyres. Once the wheels were back on the car I backed and faced the holes on the discs with thin nylon washers and then locked them down,the only slight hassle was the balancing weights being in the way which I had switched to the inside rims instead. hope this helps... Bryan
Sept 20, 2018 20:29:50 GMT
thanks for that info / very helpful
