Hi, 2001 Yaris 1.5 T sport.
Done about 126K miles, well serviced, AC works, Starts on the button, fizzy little motor at 109bhp. Purchased to run around in now surplus to requirements. Make me an offer. Note: it will have standard wheels on it unless you want to make a seperate offer for the Rota flashbacks with 3 good toyo proxes.
Bad points: Its a cat D, the paint is a bit worse for wear in places, engine management light comes on from time to time its 'Catalyst efficiency' though it did sail through the emissions check at its last MOT.
I am going to replace the exhaust system which should clear the EML permanently.
I recently serviced it and replaced both front links and the fuel tank (it was leaking but the replacement was plastic)
More pics to follow after I have given her a tidy up.
I can deliver if you really need me to, but I'd much rather you came to see it in person.
Call/text Andy on oh7718287nine86.
