scmick
Feb 15, 2021 23:02:07 GMT
Have now decided to fit a supercharged SIMCA engine in this when the bodywork is completed. It will be an uprated version of the setup in the car in thread '76 SIMCA 1000SR supercharged' on here. That has gone to a new owner put back to 1294cc standard N/A spec and he's restoring it. I kept the modified head an supercharger, manifolds etc. Plan is to use a 1442 Talbot Alpine block (longer stroke version of the 1294) and make a manifold for a 45DCOE weber carb I have in place of the big SU. Back in the days French tuners running supercharged SIMCAs used DCOEs. With the SU on the supercharger the old car used to run like a 2 litre but drink fuel like a 4 litre..!! but was worth it for the fun factor. supercharger in original car..
scmick
Feb 17, 2021 18:32:09 GMT
Exit for hot air from rad in fibreglass bonnet. ...
Feb 19, 2021 11:27:39 GMT
Morning. WOW ! That's an epic thread... I passed my test in a Simca 1000 and after going through a few "starter cars" I bought a 1000 can't remember a lot about it ( this is back in the 70's !) other than it was quite rusty and fairly quick... 1118cc and some fancy Carb (Weber)?? I know I enjoyed ragging it about though !!
scmick
Feb 19, 2021 17:52:54 GMT
greavsy I originally bought this from a lad who'd had it for his first car. He'd run it for a while then it spent years in his parents' front garden when he went on to more modern stuff. I built it up for a spare shell for my circuit racer but sold it on when I got the orange 'youngtimer' racer. Now back with me, I'm determined to get it mobile again. My other SIMCA project in the garage (see thread on here ''72 SIMCA 1000GLS') sounds like a similar spec to yours.... 1118cc and I'm fitting a 40DCOE Weber carb. It's a car we rescued from sitting under a pile of junk in a garage after the owners death in 1984. 12 years on the road had seen it get pretty rusty but it's only done 19,000 miles..!! Have completed the welding and fitted the big arched wings and 7x13 Revolutions from a past racer. Engine runs spot on with the DCOE and 4 branch exhaust. Currently in the garage to work on when the weather keeps me off the 'lightweight' outside. Starting on reskinning other front door in fibreglass...
scmick
Feb 21, 2021 18:39:33 GMT
scmick
Feb 27, 2021 11:26:19 GMT
Saving weight with lexan windows. Needed an opening bit on driver's door so used upright bit from quarterlight to make slider for rear section. Just need to bolt rear doors in place, make a cover for access hatch in rear bulkhead and can get on with mechanical jobs.... adapting Original SIMCA pedal box to a more normal setup and possibly rigging up a cable clutch release in place of the seriously 'dodgy' SIMCA setup.
scmick
Feb 28, 2021 14:00:55 GMT
Have got another pair of 8x13 5 spoke Compomotives to match the rears. Couldn't resist trying them on it. Will mess about with rides height at a later date... mainly involves juggling about with transverse leaf spring leaves at front and half a coil or so off rear springs, or may fit coilovers back there for some adjustment.
scmick
Just after taking the last couple of photos I managed to fall off the wall down into the garden below, next to where this SIMCA is parked. Now OK thanks to paramedics and brother & sister in law Kev & Lesley... if a little battered. Need to take a few days off this project... surely I can't be getting 'past it' for these jobs? Also reminds me I must do a bit of gardening.... the brambles down there don't make for a comfortable landing!!!
Dear mick. I wish you a speedy recovery. I've loitered your threads for a while but never commented. Take some time to get back to yourself an then hit the French cars head on with a strong back and a stout heart. Good luck
bstardchild
Club RR Member Number: 71
Lightweight SIMCA 1000bstardchild
@bstardchild
Club Retro Rides Member 71
Just after taking the last couple of photos I managed to fall off the wall down into the garden below, next to where this SIMCA is parked. Now OK thanks to paramedics and brother & sister in law Kev & Lesley... if a little battered. Need to take a few days off this project... surely I can't be getting 'past it' for these jobs? Also reminds me I must do a bit of gardening.... the brambles down there don't make for a comfortable landing!!! Now that was a silly thing to do - get well soon and whilst brambles aren't comfortable they do provide some cushioning - thank them before you rip them out
scmick
Since I retired I've had the time I never had when working to play about with my old cars. I probably make things harder for myself having three projects on the go at the same time. There again variety helps when one or the other gets frustrating. ... must also look into checking the SIMCA race car over for when trackdays are up and running again.
Man now that's a fleet!
And don't worry, we all do stupid things every now and again. I recently had to learn an (in hindsight very obvious) lesson not to use a chisel as a screwdriver. And I've put a Fiat through a hedge. And set light to a bootful of petrol in my Jag while I was sitting in it. I'm sure there'll be more when I start thinking!
Also, I absolutely love your little Simca mini-truck. There's just something about it. Perfect mix of unassuming utilitarian and actually quite a pretty design.
Oh, and how much do you think your lightweight 1000 will weigh by the end of it?
scmick
biturbo228 My orange ex 'Youngtimer Trophy' SIMCA racecar is supposed to weigh around 700kg using mostly steel panels, glass windows and a really substantial rollcage so I'm hoping this one saves a fair bit more with the all the fibreglass and lighter windows etc. The SIMCA Pickup has its own thread on here... '84 Simca/Talbot 1100 pickup detailing the massive 'weldathon' needed to get it back on the road in 2014. ... I've uprated it from the original 1118cc engine to a 1442 originally from a MATRA Bagheera.
scmick
Got round to finally fitting radiator in properly. On the SIMCA Rallye 2 & 3 saloons the hot air behind the rad exits under the car. On the 1200s coupe it exits via a grille in the front lid. I'm using both ways on this. Hope to make the cooling system self bleeding by 't' ing a hose from the header tank into the bottom hose into the electric water pump as used on the 'Youngtimer' racer and my 'FIMCA'. Header tank comes from my scrapped Renault Espace.
Last Edit: Mar 9, 2021 22:44:04 GMT by scmick
scmick
Mar 11, 2021 23:05:11 GMT
scmick
Mar 17, 2021 21:06:45 GMT
scmick
Mar 25, 2021 22:51:45 GMT
