tim124
Ive just pulled a 3.9 EFI engine from a disco, its very very clean, no engine number or com' ratio on the pad ( by the dipstick) The only thing I can see is stamped letters, WT WT 51 located on the pad that the old P6 rovers used for the engine number. In the push rod vally it has 10 in white marker writen twice, its a v belt engine with the cross bolted bottom end but its not been drilled / tapped for the cross bolts. the oil pump is driven from the dizzy shaft.
The engine has been painted with a silver paint, which has a very very light tint of green.
It looks like its been remanufactured by some one, any ideas? thanks
tim124
Sept 18, 2018 16:41:32 GMT
Now its been degreased it has a badge on it stating its a LandRover factory remanufactured engine, it looks like the liners are sitting on a ridge, so they should not be able to move, does any one know anything about these, is there anyway of decoding the numbers on the ali' badge? thanks
v8ian
Sept 25, 2018 1:03:04 GMT
Sounds like its whats classified as a intermediate engine
Darkspeed
Club RR Member Number: 39
Rover v8 3.9 block ID?Darkspeed
@darkspeed
Club Retro Rides Member 39
Sept 25, 2018 8:06:40 GMT
I think all the interims were 9.35 CR - If it has the full main caps then it's a good foundation for a build. How many head bolts?
tim124
Sept 26, 2018 17:03:41 GMT
its does not have the small bolts, no holes in the block the heads have had the outer holes blocked off.
Sept 26, 2018 18:15:42 GMT
its does not have the small bolts, no holes in the block the heads have had the outer holes blocked off. Hi, That's commonly known as a 10 bolt head, the earlier ones were 14 bolt heads. That will have a composite head gasket, the earlier ones had tin gaskets. Colin
v8ian
Sept 26, 2018 19:55:25 GMT
I deleted the 3rd set of bolts on my engine, never caused a problem, then later fitted a pair of TVR challenge heads, which were genuine 10 bolt heads
tim124
Sept 26, 2018 22:49:07 GMT
Yes it did have comp' gaskets, this thing is so clean inside, although a couple of the shells are very worn, Ill refresh the sucker whilst its apart,whats the opinion of Britpart engine parts?
Darkspeed
@darkspeed
Sept 26, 2018 23:51:33 GMT
Does it have the cross bolt main caps or the two bolt type?
tim124
Sept 27, 2018 0:23:23 GMT
Cross bolts, Ive just drilled & taped them for M10 bolts,its a strange match of parts, the block has the two tapped holes for a cam plate but it only has the early non located cam. Hopefully it has little core shift & the wall thickness behind the sleeves are not thin..
Darkspeed
@darkspeed
Sept 27, 2018 8:21:54 GMT
They are considered to be the best of the small journal blocks available and seldom if ever have any liner issues - I have used one for the basis of a 4.5L build - there are bits about on it in my G27 thread. They are very sought after especially once the cross bolts have been fitted.
tim124
Sept 27, 2018 11:50:02 GMT
Great news thanks, just as well as ill be fitting a turbo to this. cheers
