moglite
Club RR Member Number: 144
Aug 26, 2018 19:29:21 GMT
I'm getting to the stage where I need some brackets to make the 4-link on my Morris Oxford Traveller Is there anybody that has some 4mm steel plate, and a water-jet, laser cutter or apprentice ? Dimensions and quantities are here..... I live in Fareham Hampshire, and work in Slough, so something handy to that would be good unless you can post. I can do cash/PayPal/bank transfer whatever works for you Thanks
Aug 26, 2018 20:00:49 GMT
moglite
Aug 26, 2018 21:20:12 GMT
Thanks - but the Escort kit won't work for me, as they use a parallel 4-link with a panhard rod, or a watts linkage My solution is going to use triangulated top links and no panhard. A bit more like this
Aug 27, 2018 10:03:31 GMT
I can laser cut them but not for another week as off on holiday.
I operate out of Luton Bedfordshire if you wish to pop in.
I can cut any holes you require at the same time. I will forward you my work contact details should you want them cut.
Thanks
Aug 27, 2018 12:56:50 GMT
Pm sent
moglite
Aug 27, 2018 19:06:34 GMT
Thanks for the feedback - now sorted - great forum :-)
