I have a Toyota Hilux Surf which I bought with a poorly installed, cheap LPG kit that I immediately removed.
However, the V5C still states it is 'Petrol / Gas'.
If I want to change this to just 'Petrol', can I do this as a routine change (like changing the colour), or will it need some certificate of having been professionally uninstalled?
Thanks
1993 Toyota Hilux 2.4 Diesel 4x4 Manual 1996 Toyota Hilux Surf 2.7 Petrol 4x4 Manual
froggy
Have you had to have an mot since removing the kit . I usually see lpg stuff struggling to pass the cat test when run on petrol
Write to the Dvla notifying a change back to petrol only, they will either change it or write back asking for a letter on headed paper saying it's been inspected and you aren't lying. It's a stupid system.
Petrol / Gas to Petrol on V5CChasR
@chasr
Club Retro Rides Member 170
Apr 26, 2019 17:32:03 GMT
Tell the DVLA it's been changed via the V5.
don't you get cheaper road tax as its a hybrid (genuine question)
Rich
Club RR Member Number: 160
Petrol / Gas to Petrol on V5CRich
@foxmcintyre
Club Retro Rides Member 160
don't you get cheaper road tax as its a hybrid (genuine question) I don’t think that applies to converted LPG cars, it might do but it certainly isn’t a ‘hybrid’, it’s dual/multi fuel.
@chasr
don't you get cheaper road tax as its a hybrid (genuine question) don't you get cheaper road tax as its a hybrid (genuine question) I don’t think that applies to converted LPG cars, it might do but it certainly isn’t a ‘hybrid’, it’s dual/multi fuel. It does get cheaper for LPG cars, but you are talking £5-10 per annum tops. So I wouldn't get too excited .
You can skip congestion charges & get free city center parking with certified LPG installs
@chasr
Jul 11, 2019 16:17:08 GMT
You can skip congestion charges & get free city centre parking with London approved LPG installs Edited for accuracy . I've had certified installs and even with the green ticket issued (which TBH as 'the certificate' isn't worth the paper it's written on), they still are not exempt. The only way to make them exempt is to get the car tested in London for an emissions reduction. Lorries have had a similar thing, but for road tax etc. for years with retrofitted DPFs but I think that's been scrapped now ; It was called a Reduced Pollution Certificate (RPC). LPG alsi kicks out more CO than petrol in a few cases, hence why the MOT test differs for them under a different emissions regime using an equation to determine this if the machine does not have LPG set into it.
Last Edit: Jul 11, 2019 16:25:37 GMT by ChasR
