820
I am struggling to find a A/C gas bottle tap round handle, looking for something like in the picture below, this is the wrong size but I cant find anything. Do they have a name? or where might I find one? Square center hole 7.25mm / 0.285" While I am at it, what is the name for the holes pushed through a panel with a lip as in this picture? Thanks in advance
Jim
don't know about the handle but the holes in the lower image are called dimple dyes
820
don't know about the handle but the holes in the lower image are called dimple dyes Brilliant, Dimple dyes opened up a whole world of tools and info on google, just what I needed, thanks
I am struggling to find a A/C gas bottle tap round handle, looking for something like in the picture below, this is the wrong size but I cant find anything. Do they have a name? or where might I find one? Square center hole 7.25mm / 0.285" Thanks in advance
Jim
It might be worth paying a visit to your nearest diy centre and looking at the GATE VALVES in the plumbing section. The only problem, if you can find a compatible handle you'll almost certainly need to buy the whole valve that it's attached to.
Last Edit: Aug 4, 2018 17:06:32 GMT by MkX
820
Apologies for slow reply. Brilliant again, thanks MkX and skylinedave, really useful info. Swaged holes was the term I knew I used before. Yes might have to buy a whole valve but they are not to expensive, now I know how to find them will be easier. Thanks again really appreciate your help.
