For sale:
Turbo blanket
Oil cooler and fittings
90 degree silicone hose
Golf V intercooler
Renault 5 GT intercooler
NB MX5 passenger side electric window regulator
Metro turbo T3 elbow
Maestro T3 elbow
T3 3 bolt wastegate housing
K&N cone filter
Turbo blanket, brand new. T3 sized. Would suit externally wastegated models better as an internal wastegate arm may interfere with the blanket.
£15
IMG_20180728_120409 by Chris Witkowski, on Flickr
Setrab oil cooler, with adaptor take off and fittings. Just get your own length of pipe crimped on. The oil filter adaptor is for a Hillman Avenger, although it will fit most things with a suitable bolt.
£75
IMG_20180728_120951 by Chris Witkowski, on Flickr
IMG_20180728_120518 by Chris Witkowski, on Flickr
38mm ID silicone hose, suitable for radiator piping etc. Brand new.
£5
IMG_20180728_120436 by Chris Witkowski, on Flickr
First intercooler is from a Golf Mk5. It's big, a little too big for my Avenger project as the bonnet won't close. Pretty mint condition. Has snap fit type connectors and the effective inner pipe diameter is 2.25".
£10
IMG_20171129_132121 by Chris Witkowski, on Flickr
IMG_20171129_132203 by Chris Witkowski, on Flickr
Next is a Renault 5 GT intercooler. It's a double pass design with a thermally controlled valve which bypasses the core at low boost/temperature. 2.25" pipe connections.
£10
IMG_20171129_132148 by Chris Witkowski, on Flickr
IMG_20171129_132138 by Chris Witkowski, on Flickr
MX5 Nb passenger side electric window regulator. Works fine. I don't know if it fits NA models.
£10
IMG_20171129_132214 by Chris Witkowski, on Flickr
Metro turbo T3 elbow. A bit pitted on the outside but usable.
£10
IMG_20180206_141020 by Chris Witkowski, on Flickr
IMG_20180206_141006 by Chris Witkowski, on Flickr
Maestro/Montego?? turbo T3 elbow. Good condition.
£10
IMG_20180206_141033 by Chris Witkowski, on Flickr
IMG_20180206_141025 by Chris Witkowski, on Flickr
T3 wastegate housing. The wastegate shaft itself is slightly bent and will need replacing. Otherwise good condition.
£10
IMG_20180206_141136 by Chris Witkowski, on Flickr
IMG_20180206_141143 by Chris Witkowski, on Flickr
K&N cone filter. Slight surface rust beginning on top. Will need cleaning and re-oiling. Fits onto 2 5/8 (65ish mm) pipe.
£5
IMG_20180206_140300 by Chris Witkowski, on Flickr
IMG_20180206_140328 by Chris Witkowski, on Flickr
IMG_20180206_140307 by Chris Witkowski, on Flickr
Can post if necessary. Items all located in Huddersfield.
Turbo blanket
Golf V intercooler
Maestro T3 elbow
K&N cone filter
£15
£75
£5
£10
£10
£10
£10
£10
£10
£5
