Jul 27, 2018 10:15:53 GMT
This is a very slow burn build due to current space constraints. I'll only be posting up when I have pics to show. The aim is to achieve something like this:- First up I need to split down the front axle as its going off for the spindles to be checked and if OK having new brass bushes reamed in along with new wheel bearings to allow the hubs to be fitted on. Front beam axle: Brasss bushes have some play: Thought it would be ideal to rig up an electrolysis bath using a car battery and a smart charger. This is after a few minutes. See what its like tomorrow.
Jul 27, 2018 11:11:00 GMT
Brasss bushes have some play: understatement of the year! In for this one. Bookmarked.
mylittletony
Club RR Member Number: 84
Jul 27, 2018 11:56:38 GMT
I've enjoyed reading your previous threads, so I'm in for this
Jul 27, 2018 16:08:55 GMT
This just looks spectacular
Jul 27, 2018 19:01:16 GMT
the only word i can think of for that is delightful!!
Jul 27, 2018 19:05:57 GMT
Something a bit different, liking this.
Jul 27, 2018 19:26:53 GMT
Stuff like this is right up my street !
Right....
You have my attention too.
Jul 28, 2018 10:05:27 GMT
Me too. Liking the look of this. Although, perhaps not the play in the brass bushes...
this looks like a awesome machine of death will be following it most defiantly
1978 mk2 escort mexico
Jul 29, 2018 21:40:42 GMT
Love pre war stuff. Bookmarking this
Jul 29, 2018 21:44:21 GMT
Wonderful. Very much looking forward to seeing this progress!
This is just all kinds of awesome!!
This is the other spindle after an overnight electrolysis bath.
Slight difference there. Can I ask about your electrolysis set-up. Mine is s l o w I try and use vinegar nowadays to get shot of rust.
Slight difference there. Can I ask about your electrolysis set-up. Mine is s l o w I try and use vinegar nowadays to get shot of rust. Using a 063 exide car battery hooked to a smart charger. Positive hooked to steel plate, rusty part on the negative. Warm water with soda crystals (£1 a bag from tesco)
Slight difference there. Can I ask about your electrolysis set-up. Mine is s l o w I try and use vinegar nowadays to get shot of rust. Using a 063 exide car battery hooked to a smart charger. Positive hooked to steel plate, rusty part on the negative. Warm water with soda crystals (£1 a bag from tesco) Ah. I was just using the charger. The battery supplies a bigger flow I suppose. Do you start with warm water and let it be or do you use an element to keep temps up or?? Apologies if I'm wrecking your thread, but you got overnight results that I need days to achieve.
Gotta make sure the electrolyte strength is right (about a big tablespoon of soda per litre) and the dumb charger needs to supply at least 5amps. Anode needs to be clean plain steel.Warm water helps but not essential.
I'm only using a battery as I have a smart charger.
Managed to split the steering arm off the spindle. 80years seemed to have welded it together. Back in the bath to clean off the last bit of rust.
