Bang for buck, whats the best / accurate universal clutch alignment tool available? Basically it has to work on a bmw m52 engine and a st170 zetec one.
Thanks in advance chaps
Bang for buck, whats the best / accurate universal clutch alignment tool available? Basically it has to work on a bmw m52 engine and a st170 zetec one. Thanks in advance chaps Short length of dowel(broom handle, whatever) and some insulating tape.
Bang for buck, whats the best / accurate universal clutch alignment tool available? Basically it has to work on a bmw m52 engine and a st170 zetec one. Thanks in advance chaps Short length of dowel(broom handle, whatever) and some insulating tape. Tried that or similar and always hit and miss i got a lot of engine swaps on the go so just want the correct tool to save time and messing around
mk2cossie
Club RR Member Number: 77
Jul 25, 2018 12:34:49 GMT
I've always had a good result with the mk1 eyeball, and a torch used to shine in alone the splines Other than that, a length of something that fits in the spigot bearing or flywheel hole and tape wrapped around to fit snug in the clutch plate
Last Edit: Jul 25, 2018 12:38:52 GMT by mk2cossie
Jul 26, 2018 22:28:45 GMT
I'm going to sat the key is having the tape wrapped around uniformly around the length. This can be eyeballed as well.
Jul 26, 2018 23:39:20 GMT
I got given a Draper one, with a couple of different spline adapters. Brilliant job, up to that point i was using a half inch extension and bloody hard to get boxes on input shafts!
aaronb
Fezza nearly done
Jul 27, 2018 17:35:11 GMT
I use a laser cheap one cost a tenner and is faultless. Cheap too Available at most car parts gaff
Jul 30, 2018 19:57:09 GMT
Ive never used one, only ever done t25, mk3 golf and mk4 golf boxes. Are they only needed on certain cars or is it something to have?
gte86
Jul 30, 2018 21:19:43 GMT
I use one of these at work. At least 3 clutches a week on moderns and no problems, unless they are self adjusting clutches
Last Edit: Jul 30, 2018 21:20:27 GMT by gte86
Jul 30, 2018 21:40:22 GMT
Ive never used one, only ever done t25, mk3 golf and mk4 golf boxes. Are they only needed on certain cars or is it something to have? Proper pain in the on some boxes. Rover 75, no problem. 02Q MK5 Golf, not a chance.
