Welcome to the auction of my 1999 Lupo 1.4 16v AHW engine sprint car.
This was a car in the family from 2006 and was taken off the road in 2009 due to a diff bearing fault, as part of this I went a little bit over the top as it was replaced by other vehicle and the result is what you can see in the spec and pictures, with the aim being to print the car but keep it comfortable enough for a nurburgring trip.
This was built with a high degree of attention to detail, with many thousands spent, and hopefully from the pictures your gather apart from the shell most of the components are all brand new. Every standard nut or bolt has been replaced either by the correct item from VW where they are load bearing, or if not a stainless Allen fixing, and all bolt on brackets, sub frames, lower arms etc etc have been zinc primed and powder coated.
The car went into storage a few years back whilst I finished my house, and I’d like to move this on to let someone enjoy it. It has done around 79k, and is genuinely 100% rust free, I’ve personally cleaned the whole underside, replacing all the bolts and fixings, and used acf50 in all box sections and sills.
and In short a weekends work and you will have a read to go sprint car in the sub 1400cc category or a prime candidate for a 1.8t conversion or similar. As you can imagine from being in storage the car has no MOT, but given all the new components I genuinely can’t see why it wouldn’t fly through should you wish.
With the car will also come a Polo AFH inlet manifold and throttle body, which are incredibly rare and will up the power when combined with a suitable remap, as well as a spare subframe and the original hubs etc etc
Suspension
Bilstein B12 Front and Rear Shocks
Brand new VW top mounts x4
Eibach (Bilstein) Front Springs
CoilSpring UK custom would rear springs
GAZ rear adjusters
New Ball joints, ball joint carriers etc etc
Wheels
Team Dynamics Pro Race 1.2’s 15x6 ET38
195/50/15 Toyo R888
Chassis and brakes
Whiteline Rear ARB
Full powerflex bush kit (2x Rear Beam, 4x front arms)
Lupo GTI stich welded front subframe – powdercoated
Lupo Sport front arms stich welded - powdercoated
Lupo Sport Front Hub carriers - powdercoated
Lupo Sport front brake 256mm conversion, new VW supplied discs and pads , new pistons and seals, rebuilt by biggred.co.uk
Rear drums powdercoated, all springs, shoes and components brand news
Goodridge Braided Lines front and rear
Dot 5.1 fluid
OMP bolt in cage with harness bar
Transmission
Fully rebuilt gearbox with upgraded diff bearings, filled with genuine VW
Powdercoated driveshafts, brand new VW inner and outer CV’s and CV Boots
Brand new VW supplied hubs
Engine
All service items replaced when in storage
Ashely 4 brand manifold and decat into brand new VW system
Brand new VW supplied Radiator
Body
Rear arches professionally rolled
Both front arches replaced, 1x brand new and 1x second hand due to previous arch rolling not being required
All underside cleaned, all fixings replaced with stainless bolts
Exhaust Heatshields zinc coated
“Cambridge” rear lights
All arch linings brand new supplied from VW
2x crash bars powdercoated
Interior
LUKE 4 point harnesses
OMP wheel
Corbeau Sprint side mount seat
Radio and speakers still in place, otherwise totally stripped out
With the lack of MOT and a few final bits required such as the front indicator panel the car will need to be collected on a trailer as you can imagine
The car is advertised elsewhere, and I’m sure there is more that’s happened over a longish build that I may have forgotten, so please feel free to give me a call on 07981277256
£825 ono
Suspension
GAZ rear adjusters
Wheels
195/50/15 Toyo R888
Chassis and brakes
Whiteline Rear ARB
Dot 5.1 fluid
Transmission
Engine
Body
Interior
OMP wheel
£825 ono
