Jun 29, 2018 11:11:29 GMT
I have an audi 80 with an after market sony cd/radio and I'm looking to upgrade to DAB.
I've got some halfords vouchers so will be heading there.
Will this be easy to fit or do I really need to get them to fit it? I'm not the most technically minded, but if its colour coded and plug and play, surely it should be fairly easy.
Jun 29, 2018 11:21:50 GMT
For most applications you can get jumper cables to go from the standard vehicle connector to a din or ISO radio, if someone has already messed it around and cut wires it's obviously far more involved (but then I am not sure I would trust Halfords to sort it out either!)
Jun 29, 2018 11:36:49 GMT
I'm pretty sure youll need a dab ariel also
Fitting a DAB car stereo brachunky
@brachunky
Club Retro Rides Member 72
Jun 29, 2018 11:47:38 GMT
I'm pretty sure youll need a dab ariel also You will but check whether the stereo comes with it or not!
Fitting a DAB car stereo ChasR
@chasr
Club Retro Rides Member 170
Jun 29, 2018 12:37:48 GMT
I have an audi 80 with an after market sony cd/radio and I'm looking to upgrade to DAB. I've got some halfords vouchers so will be heading there. Will this be easy to fit or do I really need to get them to fit it? I'm not the most technically minded, but if its colour coded and plug and play, surely it should be fairly easy. It depends on a variety of things: 1) How the existing HU is wired up 2) Has someone been at your HU harness previously. If so, did they do it right? IME 2 out of 10 cars are wired correctly, the rest are a mess, with speaker phase always being wrong and generally the power wires; it's why some systems can sound terrible as a result. Why people are too tight to spend £10 on a plug&play wiring adaptor is beyond me. In the case of my Mercedes there was a potential fire hazard (positive and negative were taped at the poor joints in the same part. If it's a plug and play affair and the car has ISO plugs on it the installation is a walk in the park. The DAB aerial will need mounting somewhere but that's about it .
Jun 29, 2018 17:59:56 GMT
As already mentioned check if the radio comes with a DAB ariel if not you will need one The most common is screen mounted
Again if your radio has already been replaced with an after market one then "hopefully" it will already have a iso lead that may (if it's the same make radio) just plug in to the new radio Or you just buy the right lead If the wires have been cut then it's a different story (time consuming)
I wouldn't trust halfords to fit anything I've had dealings with them in the past and there idea of what's acceptable is very different from mine
Something else to consider is the reception on DAB radios There generally quite poor
I have one in my old Volvo using a screen ariel and it goes out of range/reception all the time to the point you no longer use the DAB function But with that said I also have one in my 5 series estate but that has a far better roof mounted ariel and that's fine
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Jun 29, 2018 18:26:35 GMT
If it's already got an aftermarket unit in there then 99% certain it'll be standard ISO plugs back there so your new DAB unit will plug straight in. (Occasionally the permanent battery live and the ignition fed live will need swapping over but that's easy enough - most looms have bullet connectors to facilitate that. You'll more than likely need a DAB aerial as most new DAB head units don't come with one. Screen mounted antennae are a bit naff and only tend to work properly if the wind is blowing in the right direction and the stars are aligned. You can get a splitter for about a tenner that will plug in behind your radio and split your existing aerial to give a DAB signal (active ones are better that use a 12v feed) they work ok but quality varies. Best of all is an active roof mounted DAB antenna, I always use those and never have issues. (About £20-£30) Hope this helps.
Edit: Oh yeah, and I agree 110% with DiscoStew about Halfords' standard of fitting.... I used to fit car audio for a living and after having to rectify so many of their howlers for angry customers, I wouldn't trust Halfords to fit a dustcap to my wheelbarrow. :-)
Last Edit: Jun 29, 2018 18:30:55 GMT by BigDaftAl
Al.
Went to Halfords at the weekend.
£99 pounds later I had a great stereo fitted. Sounds great, so much better than the last one. Given the reports of Halfords staff, I presume I was lucky.
Thanks for all the advice.
