sonus
Jun 23, 2018 20:59:52 GMT
Does anyone know, or now where I can search to find out, what car/vehicle this drive flange came off? It is used as a inner drive flange on my TVR Vixens upright, but is not the original item. It looks like it has been uprated to TVR Tuscan V6/Griffith spec at some time in its life. How ever no one can or will tell me what car/vehicle it came off. Any help appreciated
Last Edit: Jun 23, 2018 21:11:23 GMT by sonus
sonus
Jun 23, 2018 21:12:53 GMT
The spline is the same as J-type overdrive output shaft appearentley(?)
Dez
Club RR Member Number: 34
Jun 23, 2018 22:27:22 GMT
I think you're on the right track with the overdrive flange idea, as to me a non-square PCD on it would suggest it's for a UJ, so far more likely to be sourced from a propshaft than a driveshaft.
Jun 23, 2018 23:17:52 GMT
Hi, If they are using off the shelf parts, they would use parts from vehicles that were current at the time, before and likely to be in the future. So late 60s and on. Obvious choice would be BL or LR, my guess is LR maybe a diff flange, without measuring one.
Colin
