Boxers Only Deleted
@Deleted
Jun 23, 2018 10:43:21 GMT
Ok there are a load of them out there in fact the first internal combustion engine ever was indeed a boxer - just so that others that are unfamiliar with the term 'Boxer Engine' here is a simple explanation derived courtesy of Wikipedia 'In 1896, Karl Benz invented the first internal combustion engine with horizontally opposed pistons.[1] He called it the kontra engine, as the action of each side opposed the action of the other. This design has since been called the "boxer" engine because each pair of pistons moves in and out together, rather like the gloves of a boxer.[3] The boxer engine has pairs of pistons reaching TDC simultaneously' Those of you whom know me on here know exactly where my starting point is going be - so pics of 'Boxer Engined' cars only please
Last Edit: Jun 23, 2018 10:45:58 GMT by Deleted
Jun 23, 2018 12:10:01 GMT
One of my favorite boxer...
Jun 23, 2018 13:22:18 GMT
Flat 12, 4.9litre any good?
Last Edit: Jun 23, 2018 13:22:35 GMT by duggers
Jun 23, 2018 13:42:09 GMT
Click picture for more
Jun 23, 2018 14:30:15 GMT
The 917 is a flat 12 not a boxer, as is the Ferrari Berlinetta
Boxers Only Deleted
@Deleted
Jun 23, 2018 14:59:30 GMT
Right then for those of you that thought that Jowett just built road plugging motors Jowett R1 (same 1500cc boxer engine has in the Jupiter & Javelin) - Jowett were class winners in the 1950 Le Mans, Class 1 - 2 in the 1951 Monte Carlo rally, an outright win in the 1951 Lisbon International rally - another 1 - 2 at Dundrod in 1951, and further class wins at Le Mans in 1952 & 1953 The Wyile Javelin - Supercharged Javelin 1500cc boxer engine - successfully competed in the 1953 Australian Grand Prix and finished 9th - then went to be very successfully campaigned throughout Aus in sprints & hill climbs
Last Edit: Jun 23, 2018 15:01:01 GMT by Deleted
Jun 23, 2018 15:36:02 GMT
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Boxers Only retrolegends
@retrolegends
Club Retro Rides Member 94
Jun 23, 2018 16:55:41 GMT
Owned two, Subaru Impreza which was a great car and this little beauty with the 1600cc flat four, a fantastic car that sounded gorgeous.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Jun 23, 2018 17:56:29 GMT
Obvious one from me:-
Boxers Only Deleted
@Deleted
Jun 23, 2018 19:34:05 GMT
Tatra 97
Last Edit: Jun 23, 2018 21:25:19 GMT by Deleted
Jun 23, 2018 20:21:37 GMT
I run a foz so there has to be SF5 Forester STi here So Angles! Many throb-throb! Much Practical! WOW
Boxers Only Deleted
@Deleted
Jun 23, 2018 20:54:02 GMT
Here is one from a friend of mine,Subaru Legacy 2.5,twin turbo,better exhaust,goes like stink! He imported it himself from Japan,not a beaty queen,but therefore was dirt cheap,and as said,it goes,goes,goes... Will be restored-improved cosmetically one day.
jpr1977
Club RR Member Number: 18
Boxers Only jpr1977
@jpr1977
Club Retro Rides Member 18
Jun 23, 2018 21:02:36 GMT
My introduction to the joys of a Boxer and still one of my favourite 'point to point' cars So much so I still have the steering wheel and keys from the first one 20yrs since it met the big scrap yard in the sky (funnily enough it was rotten...)
Jun 23, 2018 22:18:59 GMT
What is the difference between a flat engine and a boxer engine? Before I make a huge faux pas and post the wrong thing.
Boxers Only Deleted
@Deleted
Jun 23, 2018 22:41:47 GMT
Boxers are horizontally opposed engines,flat engines are basically V-engines,but the degree of the V is 180 degrees,so: flat.
Jun 23, 2018 22:46:31 GMT
I had the same question. Thanks for asking HoTWire and thanks for answering hotrodder.
No pics of Ali then?
Cool thread, and I am sure there are many more.
Including some form these pages.
Boxers Only Deleted
@Deleted
What is the difference between a flat engine and a boxer engine? Before I make a huge faux pas and post the wrong thing. Not much difference visually from the outside. Both have pistons that run in cylinders parallel to the ground. The big difference comes in with the crankshaft,and how the conrod are connected to it. In a Boxer engine,each conrod has its own big end bearing journal to connect to. On a flat engine,two conrods are connected to each bigend journal . If you had a boxer crank next to a 4 cylinder crank,it would look pretty similar apart from the firing order being visibly different. If you had a boxer crank next to a flat or v engine crank,it would look totally different. Boxer engines horizontally opposed pistons move in opposite directions to each other,whilst on a flat engine they move in the same direction. Will look for a photo.😊
Last Edit: Jun 24, 2018 6:42:44 GMT by Deleted
kabman
