Jun 10, 2018 16:55:12 GMT
I have 3 old mowers in need of tlc. Looking at the exhausts and spark plugs there is a fairly large carbon build up that I would like to remove. The mowers have been serviced with new plugs etc. So I am pretty confident the mix is about right.
I don't really want to strip them down unless necessary so is there an additive that really works or a spray into the cylinder? Or a squirt of brake cleaner into the carb?
Many thanks
Jun 10, 2018 20:23:43 GMT
This gut has tested all sorts of ways of doing what you're looking at. Incidentally he has loads of other interesting back-to-back tests on tape, glue, penetrating oils etc...
Last Edit: Jun 10, 2018 20:24:09 GMT by SamR380
I've got Rovers.
taurus
Jun 12, 2018 16:54:23 GMT
I have used a spray for powerboat engines to clean burnt castor oil off model aircraft engines, and that stuff sets like rock. Quicksilver Power Tune. Whether it will touch carbon I don't know but it's the only thing I have seen clear the burnt on castor deposits
Jun 12, 2018 17:44:56 GMT
Brake fluid down the carb.
Jun 14, 2018 10:35:55 GMT
Thank you will be giving it a go.
