It's a 14point7 unit.
Only 6 hours use mapping a TVR
Can Display* & Datalog;
AFR
EGT
Boost Pressure
Oil Pressure
Air Temp
Fluid Temp
Fuel Pressure.
2x 0-5v analog inputs (datalog only)
Has a USB port connection so it can be plugged into a laptop for live datalogging.
Comes with;
Display/Control Unit
8ft lambda cable
NEW Bosch LSU 4.9 sensor (£65 on it's own!)
12" ish Pigtails for all Power/Sensor Connectors
2 Fuses & Fuse holders for the power supplies
It's missing the sticker on top of the unit!!!!!!!!!!!!!!!!
Here's a pic i nicked off the web
£160 ovno + post
*with compatible sensors.
AFR
EGT
Boost Pressure
Oil Pressure
Air Temp
Fluid Temp
Fuel Pressure.
Comes with;
8ft lambda cable
![](http://img.retro-rides.org/i/v/baracus/436e5730d2e8.jpg)
£160 ovno + post
