Hello, crashed the W202 wagon into a bloody Prius so I’m breaking it for bits.
I’ve got front brembo aluminium calipers from an S600amg (w220), and (to suit) W203 AMG rotors, 345mm diameter, included is 5mm thick tool steel spacers I had machined to allow the callipers to work on W202 hubs, also +5mm longer 10.9 bolts to suit for direct fit into w202 & w210,
Also have W220 S500 rear 2 pots and 330mm discs to suit also,
Same good pads loads of disc. Bolts to suit included.
I’m in London but can meet to deliver etc if you want,
EDIT: £200 for the lot?
pics below
pics below
