nassas
May 30, 2018 14:42:18 GMT
My car a 1979 toyota celica 2.0 st is burning oil, Id say a 5 litre 20w50 motor oil can will last me a month or so depending on mileage, on start up from cold blue smoke only for about 30 seconds.
can anybody help? A local car mechanic suggested valve stem oil seals?
Davey
Resident Tyre Nerd.
May 30, 2018 15:29:34 GMT
My car a 1979 toyota celica 2.0 st is burning oil, Id say a 5 litre 20w50 motor oil can will last me a month or so depending on mileage, on start up from cold blue smoke only for about 30 seconds. can anybody help? A local car mechanic suggested valve stem oil seals? Sounds like it could be steam seals. Any smoke on acceleration or any other scenario?
taurus
May 30, 2018 16:00:14 GMT
That does sound like the valve stem seals. They can also produce a short burst of smoke after idling for a while and also during engine braking for longer periods - eg going downhill.
The frustrating bit is that they are pennies worth of parts but a fair bit of work.
The reason for the smoke on starting is that oil is seeping past the stem seals overnight. You may find the back of the valves has some crusty bits of burnt oil on them so it's worth cleaning and lapping the valves whilst doing the job.
May 30, 2018 16:00:16 GMT
Hi, It does sound like valve guides or stem seals with smoke on start up. If you have the engine under power going along the road, then back off and then back on the power again and you get a smoke burst behind you then it's rings.
Colin
nassas
May 30, 2018 16:14:42 GMT
thank you guys, it only does it start up, there is no smoke burst when driving under power.
Thanks again Nassas
